Author: Subject: Front xr4x4 diff
carnut
posted on 1/7/05 at 11:00 AM Reply With Quote
Front xr4x4 diff
Why doesn't anyone use these?
mookaloid
posted on 1/7/05 at 11:01 AM Reply With Quote
I didn't because my Indy had brackets already in for the rear one
Liam
posted on 1/7/05 at 11:12 AM Reply With Quote
You'd also need custom made driveshafts.
liam
gazza285
posted on 1/7/05 at 11:25 AM Reply With Quote
You would also have to turn it upside down to get it to run the right way, leading to breather and lubrication difficulties.
Liam
posted on 1/7/05 at 11:58 AM Reply With Quote
It runs the same way as a rear diff actually
Liam
Mix
posted on 1/7/05 at 12:05 PM Reply With Quote
Are the ratios the same?? Not got the manual in front of me but isn't there a chain drive with a reduction to the front prop shaft ?
Mick
gazza285
posted on 1/7/05 at 12:14 PM Reply With Quote
Quite right too, I stand corrected. You're still driving it the wrong way though, and it wont be the easiest thing to fit due to the already mentioned driveshaft problems. How is the nearside transfer drive shaft located anyway? Looks to be a lot of work when you can use a rear diff so much easier.
[Edited on 1/7/05 by gazza285]
Guinness
posted on 1/7/05 at 12:45 PM Reply With Quote
One of the drive shafts goes through the sump on the 2.0l XR4x4 that Ben Copeland stripped.
HTH Mike
Liam
posted on 1/7/05 at 04:20 PM Reply With Quote
Originally posted by gazza285You're still driving it the wrong way though,
Right you are. And i guess it might not enjoy that for too long.
The ratio's exactly the same as the rear, Mix - there's no reduction in the transfer chain.
Fitting shafts isn't that terrible. As in a dax rush 4x4 front, you can do away with the intermediate shaft and plug two driveshafts straight in the diff. You have to machine a different oil seal for the side that usually has the intermediate shaft, that's all. Of course you'd then need to lengthen both standard front shafts if you want the diff in the middle.
If you want a light alternative to the normal sierra rear diff, the Landrover Freelander diff is a popular choice.
Liam
Ben_Copeland
posted on 2/7/05 at 02:50 PM Reply With Quote
Yep, you'd need to mount the sump as well
Ben
Locost Map on Google Maps
Enter Your Details Here
stevebubs
posted on 3/7/05 at 02:03 AM Reply With Quote
In which case could you not use it for a VTEC engine? Just need to find a RWD gearbox which will rotate the "wrong" way...
posted on 3/7/05 at 08:56 AM Reply With Quote
hold on a minute! if the diff is going the wrong way, and the engine too, and the gearbox, you'd still be moving forward with the diff running backwards! and if it was a backward spin engine, with a normal box, you'd have 5 reverse gears, but with the diff at least happy thinking all is well!
