tom_loughlin
posted on 1/7/05 at 08:54 PM |
oil pressure & water temp sender
hi guys,
2 questions, but kind of along the same lines.
1. i already have an oil temp sensor on the block of my 1800 cvh - something to do with the ecu - my question is can i replace it with therevotec
sender i have for my oil pressure gauge - and join the existing wire to the one going to the 52mm oil pressure gauge, or do i need them both, using a
't' piece?
2. my water temp sender, where and how is the best place to mount it?
cheers
Tom
posted on 1/7/05 at 09:00 PM |
Not sure about oil.
Water temp are typically mounted towards the highest part of the engine, usually into the head. I've seen them mounted in a T from the header
from engine to inlet rad.
HTH
DarrenW
posted on 5/7/05 at 10:05 AM |
I dont know if this helps tom. My engine is 2.0 pinto. It has a pressure sender that operates the low pressure warning light. My new sender is a dual
type fow low pressure warning and oil pressure guage - 2 outputs so i can connect two wires.
I also have to connect an oil temp sender - im replacing the oil gallery plug with an adaptor so i can screw in the oil temp sender.
I would have thought you will also have a low oil pressure sender???? Perhaps you can replace this with a dual type to operate theoil pressure gauge
as well and leave the oil temp sender alone (try ETB website for potential source).
