motster
posted on 10/7/05 at 12:51 PM |
Heat resitant tape
I am trying to make more air go through my rad by taping heat restant board to the sides of the rad with gaffa type tape. The problem is that the
heat is making the glue on the tape melt. Can anybody tell me where to get some high heat tape or suggest another way of doing this?
MkIndy7
posted on 10/7/05 at 12:59 PM |
There's a silver foil tape that can be used to seal flue's with, it can usually be scourced from a ducting\ insulation\ boiler spares
type places.
So that should be well within its limits, although it does tear quite easily.
Not sure of the price cos i always get in on the works account
You could maybe rigidly fix it with nuts or bolts and big washers to spread the weight?
[Edited on 10/7/05 by MkIndy7]
motster
posted on 10/7/05 at 04:06 PM |
Thanks for that. I cant bolt it on as it is the side of the rad that i am taping it to.
tom_loughlin
posted on 10/7/05 at 06:27 PM |
tape is 40ish squid from a shop, but ive found some on ebay for £19 a roll which seems more reasonabe
Tape
Tom
