wicket
posted on 26/12/02 at 10:00 PM |
Flywheel Bolts
I am removing the flywheel from my 1600 x-flow to replace the ring gear, should I replace the bolts with new ones when re-fitting ?
kingr
posted on 27/12/02 at 10:12 AM |
It is worth replacing them, especially since they're not very expensive. Last thing you want is the flywheel coming off. That nice sharp new ring
gear would probably slash your legs off a treat.
Kingr
theconrodkid
posted on 27/12/02 at 02:47 PM |
and dont forget the loctite
kingr
posted on 28/12/02 at 12:04 AM |
Hmmm, good point Hicost, sorry to appear scaremongering. Either way, if nothing else it's an inconvenience. Did you replace the bolts before they
broke, or were they rusty and nasty?
Kingr
johnston
posted on 28/12/02 at 11:09 AM |
i think the flywheel story comes from highly tuned minis
Stu16v
posted on 28/12/02 at 05:18 PM |
Seen a flywheel explode on a Mini once at a grasstrack meeting. A JCB had to be called in to dig a piece of flywheel out of the track. This piece of
flywheel had gone through the the front bulkhead and the floorpan first.....
Luckily the driver escaped unscathed but it does make you think.
Jon Ison
posted on 28/12/02 at 08:10 PM |
there was a fatal accident in autograss involving a rear mounted mini engine in a single seater, flywheel parted company, you know the rest, the rule
book now asks for a 1/4" plate on the rear bulkhead inline with any transverse mounted engines, nuff said, replace the bolts, and dowel too if u
can........
locost7-online.com
posted on 29/12/02 at 10:44 AM |
ARP Bolts
Hi We keep ARP bolts in stock cant tell you a price untill i go back to work on mon if anyone is interested.
We also Dowel the flywheel on
John
www.rollingroadtune.co.uk
