Author: Subject: What power?
Lotusmark2
posted on 11/7/05 at 01:04 PM Reply With Quote
What power?
OK guys, IDEAS Please
This is the rear compartment for my Formula Ford, It is designed to take a X-Flow and Hewland gearbox but I really dont want to spend well over £1000-£2000 on a second hand Hewland gearbox.
Any ideas what other power/trans will fit (for the purpose of this please ignore bike power as that is a whole other topic)
I know measurements would be good but the car is about 250 mile away from me at he moment so suggestions welcome.
Mark
carnut
posted on 11/7/05 at 01:08 PM Reply With Quote
You could fit an audi like the yellow mk gtr demonstrator.
Lotusmark2
posted on 11/7/05 at 01:13 PM Reply With Quote
Just had a look on the MK site but no GTR, any ideas what unit they used and pictures?
ned
posted on 11/7/05 at 01:46 PM Reply With Quote
assuming you want to leave the chassis as is you're limited to transaxle gearbox and inline engine as i see it, so vw/audi and renault units are the comonly available ones, whether they fit or not is another question I can't help with I'm afraid, though i would be interested to hear the outcome as there is a ff1600 without a gearbox or engine sitting in pieces at a friends house....
Ned.
beware, I've got yellow skin
Lotusmark2
posted on 11/7/05 at 01:50 PM Reply With Quote
I know the car is setup for a beetle diff at the moment so any VW expects that can tell me what trans will mate up.
Ned... get that FF mate, if the worst comes to worse you can always go bike power.
ned
posted on 11/7/05 at 02:07 PM Reply With Quote
lack of garage space is the problem, buts its sitting in a barn that i know where the key to is at the moment, so maybe eventually. we shall see. my preference (though i know you said bike engines are another thread) would be a cbr1000 or other goodcheap bike engine inline, coupled to a sierra dif with a double u/j something like spunky did in his car.
Ned.
NS Dev
posted on 11/7/05 at 02:45 PM Reply With Quote
you can use a beetle transmission. A lot of people in autograss (where I race) use them, with modified internals. The cost depends on how many gears you need. Most of the grassers use hewland gears inside the beetle casing.
The other option is the audi box, again used by a lot of grassers so there are adaptor plates available.
Lotusmark2
posted on 11/7/05 at 02:52 PM Reply With Quote
great, sounds like we are getting somewhere, Dev do you have any pictures or links on these transmitions?
what engine are you putting through the beetle box?
madman280
posted on 11/7/05 at 04:49 PM Reply With Quote
The original Hewland transaxles were modified VW ones. heres a link to the history of Hewland transaxles: http://www.hewland.com/svga/history.htm
This page may be of some use to. The drawings and pictures might be useful. http://www.hewland.com/svga/homeIE.htm
Volvorsport
posted on 11/7/05 at 05:44 PM Reply With Quote
yeah , early hewlands were VW with magnesium casings .
you can turn the diff round to make the mid engined , and theres plenty of adapter plates , but youll be stuck to about 130-140 hp before mods are needed like diff side plates which break .
the transporter ones were able to take more power and are 5 spd , beetles are just 4 speed .
then theres ratios and diffs which might not be suitable so , maybe look at a better option in the first place , depending on what application your building it for , My mates next door to me have , beetle boxes lying about ! , i believe theyve also got a couple of transporter boxes .
ive got a renault box and its pretty heavy .
try a secondhand staffs box , they might be a bit more cheaper than a hewland .
www.dbsmotorsport.co.uk
getting dirty under a bus
Lotusmark2
posted on 11/7/05 at 07:04 PM Reply With Quote
Cheers Volvo
I am mainly looking to use it on track days so I would think 140 BHP should be more than enough when the car is going to weigh about 350kg.
If you know of any transporter boxes that I could get to Lancashire (I cant drive at the moment due to detached bicep)then please let me know
ned
posted on 12/7/05 at 08:59 AM Reply With Quote
Friend of mine's sports 2000 race car has a beetle cased mk9 hewland box, he used to run a vauxhall xe with it and it would occassionally break 2nds and thirds and he had to be careful with it off the line, he ended up 'lifing' 2nd's and changing them quite regularly. I understand that FVL used upgraded mk9 gears in their own casing, not sure of the details, but they must have put down reasonable power.
Ned.
Lotusmark2
posted on 13/7/05 at 05:44 AM Reply With Quote
Thanks for all the feedback guys.
After much umming and ahing I am going bike power with a fire storm Vee twin 1000. should go quite well
davidwag
posted on 14/7/05 at 08:57 PM Reply With Quote
Hi
Do you know who manufactured the chassis?
looks dead simple to make.
Could be just what i'm looking for for my next hill climb car.
