Author: Subject: Overheating
motster
posted on 12/7/05 at 06:14 PM Reply With Quote
Overheating
Can anybody tell me a cheap way of dropping the temperature of my engine. I have blocked all of the holes around the rad but it still gets very hot...help...
tks
posted on 12/7/05 at 06:26 PM Reply With Quote
earlier fan cut in temp switch...
- more powerfull fan
- bigger radiator?
- is thermostat housing ok? full opening??
- water pump ok??
check those before..
Tks
is it an new car? or an rising problem??
shortie
posted on 12/7/05 at 06:29 PM Reply With Quote
what engine?
bob
posted on 12/7/05 at 06:31 PM Reply With Quote
could be air lock
Have you any pictures of the set up ?
what engine ?
posted on 12/7/05 at 06:42 PM Reply With Quote
Red Line Water Wetter about £15.00 a bottle . Drops the temperature by as much as 15degrees C
shortie
posted on 12/7/05 at 06:51 PM Reply With Quote
mine was an airlock which I removed by bleeding the air from the fan switch in the top of the rad. Just loosened alot and then ran the engine and then waited until water started seaping from the hole and then tightened it.
HTH,
Rich.
pbura
posted on 12/7/05 at 07:08 PM Reply With Quote
Retarded timing will cause overheating, too.
Pete
NS Dev
posted on 12/7/05 at 09:23 PM Reply With Quote
..............all good questions, and the next one which I have been caught out by...............is it really overheating??
It's not uncommon for gauges to misread, especially where donor senders and other donor's gauges have been mixed.
Is it boiling and blowing coolant out?
Avoneer
posted on 12/7/05 at 10:45 PM Reply With Quote
Best bet would be for you to tell us what engine, what radiator and how you have plumbed it.
Then we can all argue about how wrong/wright it is.
Pat....
