Benzine
| posted on 14/7/05 at 09:48 PM |
Coolant route and fixings
After searching the forum with no success I thought I'd post about my coolant hoses. I have just made a nice braket for the expansion tank and
now I need to work out where the 2 pipes will go.
On the below pic: The top blue pipe goes from the top of the rad to the expansion tank. When clipped in place the hose clears the exhaust/rocker cover
etc with plenty of room but does it need to be secured down (e.g. where i've drawn red line to represent brackets coming from the rocker
cover)
2nd pipe: Can this be fixed onto the engine mount (same question for the clutch cable)?
The big fat red pipe is another potential route, fixing it to the chassis rails
Also how are pipes fixed to where they need to be? Are zip ties enough? Large P clips?
Thanks for any help
[Edited on 14/7/05 by Benzine]
| posted on 14/7/05 at 09:58 PM |
Large P Clips - I'd route them away from exhaust or are you going to heat wrap the headers?
Benzine
| posted on 14/7/05 at 10:02 PM |
Yes I was going to heat wrap them, I forgot to ask about that in my post.
ditchlewis
| posted on 15/7/05 at 07:28 AM |
Nice cam cover, who supplied it?
I have used the same pipe routing as you, but i have retained a modified original cam cover. which has some additional fixing points on it.
The donor car (ford sierra - Pinto) had some metal pipe retaining clips on it that i used on my new engine. i mounted 2 under the exhaust manifold
which i used existing bolt holes to fix into. the top hose clip was fixed onto the cam cover. you could put it onto an exhaust stud but you would have
to insulate the pipe to prevent heat transfer. See sketch attached (excuse the art work).
these clips are metal and bend easily to the required position. they can be painted up also. i will try and take a photo this weekend if you want.
Ditch
ditchlewis
| posted on 15/7/05 at 07:30 AM |
Sorry the picture did not attach
ayoungman
| posted on 15/7/05 at 07:34 AM |
I used a stainless pipe secured to the block. It runs from the pump to the heater. You could use a similar route. This is unaffected by heat from
exhaust etc. I think it is easier to fix solid tubes onto the engine and looks better.
"just like that !"
Benzine
| posted on 15/7/05 at 07:41 AM |
Thanks for the help chaps. ditchlewis, I got my cam cover from vulcan
ditchlewis
| posted on 15/7/05 at 07:55 AM |
Thought so Cool
after spending several grand on the engine i did not have enough left for the cover
may be my girl friend will be nice to me and buy me one for chrimbo
Ditch
Benzine
| posted on 15/7/05 at 08:03 AM |
When I rang they only had 2 left and I got one so hurry
