dr-fastlane
posted on 17/7/05 at 07:04 PM |
Speedometer cable is way to long
Hello,
I thought that I had chosen the easiest way when I fit the original instrument cluster from my donor Sierra. Now I realise that the original
speedometer cable is much to long.
How can I reduce the lenght of this cable? Or is there an cable from an diffrent car thats fits? I use an Type N 5speed gearbox.
Roy.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
Jon Bradbury
| posted on 18/7/05 at 06:28 PM |
Try using a circuituitous route from the gearbox to the speedo and you should be OK if you avoid sharp bends. Alternatively there are some cables that
are compatible and shorter - ask a Ford dealer, I think the Transit van uses the same couplings but is shorter.
