Author: Subject: Zetec to MT75
Chaz
posted on 17/7/05 at 09:50 PM Reply With Quote
Zetec to MT75
I have my 1.8 Zetec, I WILL make it fit to my MT75....but just need some help. To make things clear i'll do the "back bone connected to the..hip bone" method.
1.8 Zetec connects to 1.8 Zetec standard flywheel
Flywheel connects to the Sierra DOHC clutch disc
Clutch disc inbetween flywheel and the standard 1.8 Zetec clutch plate
Next fits the thrust bearing about 20mm larger than a normal one.
Ok. The problems are; Everyone has told me to use a 1.8 Zetec clutch. It wont fit onto the splines (too small, but the actual disc is same overall size), but my old DOHC sierra one does. Shall i go and get a new one of those or use another type similar to the DOHC.
Which thrust bearing? Some said westfield, and i've had other ideas. What works? I'd suppose it's ok as long as its an extra 20mm in depth and it fits onto the splines, its ok?
zetec
posted on 17/7/05 at 10:03 PM Reply With Quote
Give Dunnel a call, they supply a clutch for zetec to MT75 using a unmodded Sierra DOHC release bearing. They are a huge source of knowledge re zetecs.
Chaz
posted on 17/7/05 at 10:17 PM Reply With Quote
Dunno who Dunnel are, or their number, but i'll find out. Thanks.
Thanks for the number, and tinternet site!
[Edited on 17-7-05 by Chaz]
zetec
posted on 17/7/05 at 10:28 PM Reply With Quote
Sorry mate, 01449 677726. They are big into zetec tuning/parts/engine management. Not budget but they do some good stuff, and as said know loads on the subject.
Dunnel.co.uk
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
