Author: Subject: Tidying up ignition leads?
posted on 26/7/05 at 10:11 PM Reply With Quote
Currently the ignition leads on my x-flow go straight from the dizzy to the plugs, and flap around against the bonnet, etc.
Can anyone suggest a neat clip that I can screw or stick to my rocker cover to keep them in place? I'm thinking of the sort of clips you find on Vauxhall Astras - 4 sprung plastic clips in a row. The only problem is that my plug leads aren't standard diameter - I think they're 8mm or larger.
posted on 27/7/05 at 02:42 PM Reply With Quote
What - no opinions?
This forum is slipping!
DJ
timf
posted on 27/7/05 at 03:01 PM Reply With Quote
try
stevebubs
posted on 27/7/05 at 10:18 PM Reply With Quote
vehicle wiring products do clips and also numbers for HT leads
posted on 28/7/05 at 07:36 AM Reply With Quote
I had seen these products - Tim's clips and steve's numbered clips will hold the leads together, but they won't fasten them down. What I'm trying to emulate is the original x-flow system, where the leads are held in a rubber gizmo that's held to the rocker cover by a bit of bent steel... or, to be exact, I want to hold the leads down but I want to look a bit less naff than the original Ford system!
I think I'm going to have to make something...
rgds,
James
posted on 28/7/05 at 09:59 AM Reply With Quote
What about the plastic clip that's used on the side of a Sierra rocker cover?
It's a plastic strip about 60mm long with plastic 'tines' that stick up and you press the leads between them.
I don't have a picture but it's small and light.
On the back it has a plastic 'dome' that pushes into a steel tab to secure it but you could cut off the dome and glue the strip to your rocker cover.
Any use?
HTH,
James
timf
posted on 28/7/05 at 10:18 AM Reply With Quote
what about a set of these
fixed to a bracket on the side of the rocker cover
msd part no MSD-8841
posted on 28/7/05 at 12:01 PM Reply With Quote
They look interesting... who's MSD?
DJ
timf
posted on 28/7/05 at 12:47 PM Reply With Quote
msd ignitions possible the largest aftermarket ignition supplier in the world
best bet to get some is to give give real steel a ring with the part number
