mad4x4
posted on 29/7/05 at 07:28 PM |
CHV -> Zetec
Ok need an answer to this if I get a zetec what will I have to change on the engine to get it to fit my type 9.
Clutch? FlyWheel?
Currently I have a 1.6 CHV installed and am thinking about Zetec
Scot's do it better in Kilts.
davidwag
posted on 29/7/05 at 07:44 PM |
If you are using a standard CVH flywheel at the moment, then the standard 1.6/1.8 fiesta /Escort zetec flywheel should be ok.
stevebubs
posted on 29/7/05 at 08:02 PM |
Normal things to make it mount are:
flywheel (only if fitting a 2.0)
clutch
spigot bearing
You'll also need to trim down the middle of your current engine - gearbox spacer plate
Don't forget to lower the zetec sump, too
Use your CVH starter.
S
[Edited on 29/7/05 by stevebubs]
mad4x4
posted on 29/7/05 at 09:19 PM |
What do you mean "Lower the Zetec Sump"?
zetec
posted on 29/7/05 at 09:24 PM |
The later zetec has a cast sump which has to be trimmed to allow the starter to fit the type 9. The earlier zetec does not need this to be done as
there is enough room for the starter to miss the sump.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 30/7/05 at 09:13 AM |
You nee to change one engine mount -- I can't remember which
mangogrooveworkshop
posted on 30/7/05 at 09:27 AM |
Upgrading again! Ps your pictures are in my archive.
stevebubs
posted on 30/7/05 at 03:52 PM |
Depending on your installation, if you use the std zetec sump you may have clearance issues with road bumps...the answer to this is shorten the sump
posted on 30/7/05 at 04:17 PM |
That would be raising it then
stevebubs
posted on 30/7/05 at 04:34 PM |
