Author: Subject: It Lives!!!!
wicket
posted on 1/8/05 at 09:08 PM Reply With Quote
It Lives!!!!
After 3 & 1/2 years work it started 1st time tonight all be it only for a few seconds. What a brilliant feeling, it makes it all worth while.
Later we managed to get to running for awhile & when the exhaust manifold started to heat up the heat wrap smoked & began to change colour, is this normal ?
omega 24 v6
posted on 1/8/05 at 10:08 PM Reply With Quote
Well done mate. Yeah lots of smoke as i recall but so long ago that i can't recall the colour change.
andylancaster3000
posted on 1/8/05 at 11:26 PM Reply With Quote
Well done, i bet its a great feeling, wish i was that far .
I've just seen the pictures of your pedal box which is just like what I have been thinking of doing. Quick questions: What pedal ratio, master cylinder size and caliper combination did you use?
Thanks,
bimbleuk
posted on 2/8/05 at 07:40 AM Reply With Quote
Don't worry about the smoke. The heat cures the wrap and it goes quite stiff.
wicket
posted on 2/8/05 at 07:50 AM Reply With Quote
Thanks for the comments.
Its a Luego pedal box, 0.625" Girling m/c to the front & 0.7" to the rear, std Cortina calipers at the front & Cortina axle with 8" drums at the back.
I think the pedal ratio about 5 to 1, it comes with the pedal box, I can measure it if you need to know more accurately.
andylancaster3000
posted on 2/8/05 at 08:57 PM Reply With Quote
Thanks for that...of great help!
