piddy
| posted on 2/8/05 at 08:09 PM |
zetec in 7
zetec in 7
hi has any one fitted a 1800 zetec from Escort/fiesta in to a 7 without doing to many mods to the inlet camber? and using the original wiring ECU etc?
thanks
Mansfield
| posted on 2/8/05 at 08:13 PM |
If anyone answers yes to this, it will be the way I am going.
The general opinion is the injection side of things is too large. Bum.
Micael
| posted on 2/8/05 at 08:42 PM |
I use the original ECU, but i have made a new plenum chamber.
It works fine
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
Mansfield
| posted on 2/8/05 at 09:09 PM |
Micael
Do you have any pictures of this?
donut
| posted on 2/8/05 at 11:56 PM |
I'll be putting in a 1994 2 litre zetec in my Indy and will be using Kawazaki ZX9R carbs on a home made inlet manifold. To get the engine
working i will be using the coil pack, edis4, crank sensor and probably the megajolt to get it running.
Seeing as how exaust are so expensive i'm looking to use the orig exhaust manifold with a custom pipe to a rear can. Not sure if this method
will work but it's worth looking into!
Micael
| posted on 3/8/05 at 10:37 AM |
Yupp.
The plenum is made of an 3" exhaust pipe and some 6mm steel sheets.
buildi
ng the plenum
on
e more
In
place
Micael Moose Åman
2009
Schrodinger
| posted on 3/8/05 at 12:18 PM |
I have used a 1.8 Zetec in my Tiger Cat with 2.0l cams and home made throttle bodies from a pair of 40 Webers.
