Big Stu
posted on 5/8/05 at 04:17 PM |
Resistor in airflow meter.
Does the urban myth about putting a resistor inline with the airflow meter create more BHP? Has anyone tried this?
nanosleep
posted on 5/8/05 at 06:23 PM |
I believe this will lean the mixture which will in fact generate more HP. However this is very harmful to the engine. You'll hear the guy say
"My engine is running better than it ever has" about two laps before the piston becomes small pieces of piston.
I definitely would not use this method. The perfered method is some sort of re-programmable ECU. In either case you'll want to use a wideband
air/fuel measurement when turning.
-Andy
2000 Mustang GT
2003 Mustang Cobra 450RWHP/450RWTQ
2004 ZX-10R
In progress: 67 Mustang with 520ci(8.6L) V8, 600HP estimated
posted on 6/8/05 at 10:13 AM |
The airflow meter is a 0-5v 3 wire sensor hotwire and mechanical varriable ressistance type essentially are interchangeable, essentially it is a
bridge circuit the output voltage increases with airflow, any change made by fitting an additional ressitor will have a many times larger effect at
idle than under load.
