Author: Subject: Gearbox identification
Paul (Notts)
posted on 24/8/05 at 04:36 PM Reply With Quote
I have what I belive is an LT77 gear box out of an SD1 in the garage but would like to check serial number to prove origin and age , allso gear ratio's.
The box has the following stamped on the side of it..
16J7
V3334
and aslo what I think is a british layland stamp and a large V which turns into an F folowed by a number 1.
Any ideas about sites with info would be helpfull
thanks
Paul.
posted on 24/8/05 at 05:33 PM Reply With Quote
To get he ratios just put in each gear and count the turns
MikeR
posted on 24/8/05 at 05:52 PM Reply With Quote
have you tried googling for the information. I've just looked up LT77 and found more information about the box than i could ever want to know.
Did you know the spacing between the shafts is 77mm in the LT77 and the LT stands for Leyland Transmission.
