Ian Pearson
| posted on 9/9/05 at 09:43 AM |
Bellhousing
Having read the article in Septembers PPC, I've decided to attempt to make an adapter plate to mate the 3SGE to the type 9 box.
I'm looking for a bellhousing and the following are boxes that are supposed to mate to the 3SGE. I'm not sure if the bellhousings will
split from the all the gearboxes, so if any of you have any experience/knowledge of them, I'd be grateful for your input.
W55
W50
T50
Regards, Ian.
NS Dev
| posted on 9/9/05 at 10:10 AM |
as a most unhelpful aside!!!!..........
in the past I have been involved with making an adaptor plate from a getrag gearbox which was only available with an integral bellhousing. On this we
bandsawed off the gearbox casing just behind the front bearing area, then machined this area flat in the lathe and then followed along the lines of
the ppc article.....................
just to point out you don't have to have a removable housing as long as you can sacrifice a gearbox!
albertz
| posted on 9/9/05 at 12:55 PM |
I managed to make my own bellhousing to join the Toyota 4AGE engine to the type 9. I used two aluminium bellhousings, one from each donor. I was
slightly fortunate that the length of the input shaft on the type 9 was longer than the Toyota bellhousing, which resulted in "simply"
machining the flange off the type 9 housing and offsetting and welding it to the Toyota housing. This meant that i kept the toyota clutch mechanism
excatly as per the manufacturer intended and simply repaced the clutch plate for a Sierra plate, which is needed to match the splines of the input
shaft. The main issue was establishing the overall face to face length required and centering the box and the engine, other than that locating a
suitable spigot bearing was the only other hassle.
It works perfectly well and only very occasionally jumps out of 4th on the over-run (probably slightly out of alignment). Not that i am too bothered
about that right now. There are a couple of pics in my archive.
owelly
posted on 9/9/05 at 03:58 PM |
http://ppcmag.co.uk/forum/topic.asp?TOPIC_ID=32&whichpage=1
might be of some use??
Trev Borg
| posted on 10/9/05 at 04:33 PM |
I wish i'd thought of that!!!!!!!
That looks like a great project.
Hope it goes well for you
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
liam.mccaffrey
| posted on 10/9/05 at 05:00 PM |
i rather do that and f*$k it up a few times than pay the money for a bellhousing
Build Blog
Build Photo Album
Trev Borg
| posted on 10/9/05 at 05:25 PM |
if there is a bellhousing available, the choice of making one or buying would be nice. But if there is not one you can buy of the shelf, your options
are limited.
Making my Engine RWD was not easy, but it looks like its goona work.
Main problems areas are.
original sump was very deep
fabricate new shallow wide sump, fit oil accumulator.
Flywheel has no spigot bearing
Find one that the correct outside diameter for the hole in the flywheel (if it has one), and the correct in side diameter for the gearbox shaft.
No off the shelf belhousing available
Calculate face to face length for bellhousing and fabricate the bloody thing.
What clutch plate to use
original alfa was 228mm diameter, and the ford box needs a 1" 23 spline plate
Solution is fit a Galaxy clutch plate as it does the business ( this took a lot searching to find the right one)
Clutch operation and bearing.
either use the clutch arm from the engine donor, gearbox donor, or fit a concentric one (mondeo, or saab) what ever takes your fancy.
All in all, i would say do a bit of research before attempting a one off.
Bollox!! what am i saying 'JUST GO FOR IT'
[Edited on 10/9/2005 by Trev Borg]
| posted on 10/9/05 at 06:40 PM |
The other option is an adaptor if you have room for it. One side drilled and countersunk for allen heads into the engine and the other drilled and
tapped for your bellhousing bolts. An idea of it here mating a V8.
Volvorsport
| posted on 10/9/05 at 07:21 PM |
you could always make a centering ring that fits the sleeve of the gearbox , and locates the bellhousing .
all the getrag conversions you can buy in sweden have this item .
www.dbsmotorsport.co.uk
getting dirty under a bus
gazza285
| posted on 10/9/05 at 08:16 PM |
That is how I did it when I put a Pug diesel into my T4 van. I turned up a spacer to go between the Pug crank and the VW flywheel so the clutch was in
the same position as well.
Ian Pearson
| posted on 10/9/05 at 09:55 PM |
Not sure if I'm barking up the wrong tree or not. Does the bellhousing from the short input shaft Type 9, fit the long input shaft Type 9? If
so, provided I can sort out a spigot bearing and clutch to fit the 3SGE, the adapter plate should take care the extra length of the input shaft?
owelly
| posted on 11/9/05 at 09:38 AM |
Yes. The bellhousings are interchangeable.
http://www.ppcmag.co.uk
Ian Pearson
| posted on 11/9/05 at 08:36 PM |
Thanks All.
Am I correct in thinking that the long input shaft box came from V6 powered cars?
[Edited on 11/9/05 by Ian Pearson]
Liam
| posted on 11/9/05 at 09:07 PM |
Dont know if the 4-pot bellhousing is any shorter than the V6 bellhousing - the longer input shaft might just be cos the spigot hole is a bit further
away on a V6. You really wont know how your combination is going to work out until you have all the bits and taken some measurements! I made an
adaptor plate for my combo and had to take up the extra space (even more than the plate thickness as it turned out) with a custom flywheel (good job I
have a cnc machining buddy!). Count yourself lucky you have a removable bellhousing to chop up!
Liam
NS Dev
| posted on 11/9/05 at 09:40 PM |
Liam
quite!
just as the point I made earlier, if not you'll need to start chopping up a gearbox!
| posted on 11/9/05 at 10:32 PM |
I made an adaptor plate for my combo and had to take up the extra space
Cut some off the input shaft if it's too long?
| posted on 12/9/05 at 10:20 AM |
Makes it tricky to get the remaining "stump" into the spigot bearing I would think!
