Author: Subject: pinto injection
dave blissett
posted on 23/1/03 at 08:48 PM Reply With Quote
pinto injection
i am looking for a 2ltr pinto that i can run with twin 40s all the 205 blocks i can find seem to be injection is it posable to fit twin 40s on a injection head and if so were can i get the manifold from
all the best dave
david walker
posted on 23/1/03 at 09:33 PM Reply With Quote
All the sidedraft manifolds I've seen will fully cover the inlet ports on an injection head. Despite what is often said (including on here) so will most Ford downdraft manifolds also.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
James
posted on 24/1/03 at 07:08 PM Reply With Quote
Vulcan manifold
Aha, a can of worms question...
The '205' only came as injection as far as I know.
I'm led to believe that the reason the engine has more bhp is because the gas flowing is better in the '205' cylinder head (as opposed to is being because of the injection).
see:
http://www.pumaracing.co.uk/pinto.htm
Bear in mind the '205' has pear-shaped inlet ports as opposed to the circular 'carb' Pinto.
I wouldn't want to argue with anyone about being able to fit carbs directly to this (205) head I don't know enough to speak with authority. All I wish to point out is that Vulcan Engineering sell a manifold to go from weber carbs to the '205'.
A picture of it is here:
http://forum.locostbuilders.co.uk/xmb/photos/cgi-bin/showpic.pl?adapter.jpg
It costs £87 +vat
If you choose to use this then with air filters you will need 9" between your head and the chassis rails to fit it in.
See, nothing but facts and no opinions!
James
sg_frost
Builder
Posts 104
Registered 6/11/02
Member Is Offline
Photo Archive Go!
Building: Haynes roaster in college with students, gulp!
posted on 24/1/03 at 10:38 PM Reply With Quote
We've run a fair few rally escorts with pintos before now, most with the 205 engine (thicker block, hence stronger, ish) Had single 45 webers on these with no problems, so I cant see any problem with twins.
Stu16v
posted on 25/1/03 at 12:21 AM Reply With Quote
The 205 block was also fitted to the Transit (in factoriginally fitted to the Transit AFAIK). And they didnt run injection either. BUT most, if not all, will have low compression pistons fitted, means that you can run on any cheap poo fuel you like, but not good for power.
Cheers, Stu.
dave blissett
posted on 25/1/03 at 06:16 PM Reply With Quote
thanks for the help i got the 205 engine
i cant decide whether to keep the injection
and sell the delortos or fit the carbs
can anyone sugest power output figures for a 205 with twin 40s if its not much differance the carbs are for sale
Mark Allanson
posted on 25/1/03 at 09:16 PM Reply With Quote
The 205 engine in the sierra runs at 9.2:1, not exactly low compression, you can check it by looking at the chassis plate, it will say N4 or N4A in the engine section.
You can run it on unleaded but you must turn the timing back 4 degrees to 8 BTDC
macspeedy
posted on 25/1/03 at 09:28 PM Reply With Quote
Pinto
Pinto injection heads have a slightly different port shape that flows better than a standard head, this head is commonly fitted by stock car racers they are heavily restricted to what porting they can do. the main area that is workable (worth while working)is quater of an inch either side of the valve seat, I would recommend balancing the bottom end of your engine, there is no point of buying or working a head when the other half is'nt in "tune", also gives you a chance to make sure crank and conrods are not bent! . Also buy one of the many books available an easier read is How to power tune Ford SOHC by Des Hammil. Without spending silly money you could get 140 bhp a slightly wild cam would be a good option, as no doubt the one you got out your doner is sh****d and the spray bar will be full of crud! one last thing there i have heard there is a cut of point for which pair of carbs to go for 40's 45's around the 140 150bhp mark. A coil pack with electronic ignition will help to keep things running smooth, look out for Classic ford mags as there are plenty of articles on tuned pintos and spares for sale!! good luck with your build.
