gutball
posted on 14/10/05 at 10:26 AM |
rivets
Whats the type of rivets that are closed and leave a chunk of the mandrel inside so there's no hole?
Don't tell me, its closed isn't it?!?
After some stainless ones.
posted on 14/10/05 at 10:33 AM |
You are describing 2 different things!
There's the closed-end rivet, which has the end that goes into the hole fully closed (obviously!).
There is also the rivet that leaves the mandrel across the join, which makes it very strong in shear. "Cherry" is a name that comes to
mind.
If your lucky, you may find rivets that are closed, and leave the mandrel in place!
Confused? You will be!
andyace
posted on 14/10/05 at 10:42 AM |
www.prifast.co.uk
Closed end rivets, alu body, stainless mandrel 4 x 9.5
£22.97 per 1000
email : mailroom@prifast.co.uk for more info
Mix
posted on 14/10/05 at 11:14 AM |
Standard pop rivets will retain the head in the tubular section of the rivet provided the correct length rivet is used.
Belt and braces method is to dip the rivet into adhesive before setting
Cherrys and others like them are technically structural rivets, much stronger, manufactured to aircraft specification and hence a tad expensive.
Mick
Bluemoon
posted on 14/10/05 at 12:17 PM |
Sorry to highjack the thread, but what type of rivets are poeople using?
I'm worryed that the cheaper Pop rivets will undo with vibration Monobolts seem ideal, but expensive.
Dan
andyace
posted on 14/10/05 at 12:32 PM |
As above Closed end rivets, alu body, stainless mandrel 4 x 9.5 for fixing ali panels sealed with PU adhesive..
When popped adhesive forces around the rivet nicely sealing off any way into the chassis.
Strolls
posted on 14/10/05 at 12:42 PM |
quote: Originally posted by andyace... sealed with PU adhesive.. When popped adhesive forces around the rivet nicely sealing off any way into
the chassis.
Sorry... dumb question... what's "PU" adhesive? A Google just returns a bunch of Chinese glue manufacturers.
Stroller.
chrisf
posted on 14/10/05 at 12:58 PM |
He's looking for the aircraft spec Cherry Q rivets--as the others mentioned. The cheapest place I've found them is at
Aircraft Spruce. They are in the US but ship internationally for reasonable cost. Their website is a bit of
a nightmare to figure out what rivet is appropriate though.
I used the Cherry Q alu rivets with a alu shank. They also have monel shank rivets--which are a bit more.
--Best of luck, Chris
posted on 14/10/05 at 01:05 PM |
Stroller.
Polyurethane adhesive - trade names include Sikaflex, Tiger Seal, and so on. Comes in those industrial tubes with a spout, which you have you put into
a handle thingy that squeezes it out.
V. sticky, and gives a very strong but flexible bond - with good surface preparation it's almost impossible to break it.
The brands I named are the most expensive - the better on-line decorators' supply houses sell it far cheaper.
_Aero_
posted on 14/10/05 at 01:06 PM |
PU Adhesive is Polyurethane Adhesive. There are a number of types available... mostly based for Marine Work seem to perform best. Tradenames include
Texflex, Adflex, Sikaflex, Tigerflex etc etc. It's extremely good, too good in some cases!, and on floors with PU Adhesive standard 5mm head pop
rivets are more than adequate adding lots of chassis stiffness.
I know one guy who is considering not using rivets or mechanical fastening at all - you know who you are locost-lightening! It'll never get you
to that infamous quote of 397Kg though...
Hope this answers some questions...
