interestedparty
posted on 3/4/02 at 08:14 AM |
pinto dimensions needed
Would anyone happen to know the height (from sump to cam-belt cover) of a 2litre pinto engine. I would also be interested to know the length from
thebellhousing bolt face to the nose of the water pump (or whatever else sticks out the most). I am researching alternatives to the pinto engine.
TIA, John
Dunc
posted on 3/4/02 at 10:36 AM |
Are you using CAD? I have 3D models of 1.6 pinto, 2.0i DOHC, 2.9V6, some jap engines and various gearboxes. They are quite accurate and show intake
and exhaust, alternators, fan belts, distributors, etc. as well as mounting points.
chrisg
posted on 3/4/02 at 08:35 PM |
Dunc Baby,
I'll have the Pinto one if Poss!!
Chris
interestedparty
posted on 4/4/02 at 12:54 AM |
I'm not using CAD at the moment, but am interested in hearing reccommendations as to which program to get. In the meantime, could your program output
a jpeg I could see?
John
chrisg
posted on 4/4/02 at 09:36 PM |
John,
Just had a quick measure of my 2.0 litre Pinto, with the chopped sump(level with the gearbox bellhousing)is 545 mm from the bottom of the sump to the
top of the rocker cover i.e not including the oil filler spout.
It's 600mm from the gearbox flange to the front of the water pump.
Chris
stephen_gusterson
posted on 4/4/02 at 10:34 PM |
Chris
I was interested to see how my V6 cologne 2.4 ford (little brother of 2.9) compared.
Its 610 long and 640 high, to the top of the plegnum chamber, to the unmodded sump. Recon about 60mm could come off there if needed.
Dont compare too bad really. Acommodated extra height by running the chassis with 7.5 ins ground clearance and a 11 ins scuttle height on std height
chassis.
Refraining from mine being bigger than yours quips
bob
posted on 5/4/02 at 06:45 AM |
You might have been interested but i doubt if anyone else was
stephen_gusterson
posted on 5/4/02 at 08:30 AM |
I got a tape measure and im gonna use it
stephen_gusterson
posted on 5/4/02 at 08:45 AM |
Interesting bit of comparison (or not for Bob) :
Pinto = 115 hp injected, in say a 600kg car = 192 bhp ton.
Ford 2.9 150hp injected, is about 50-70 kg more than a pinto, so 670kg all up = 223 bhp ton.
These are std engines, with no expensive twin carbs or trick mods.
For Jon, yep, a bike engine is much better - say 520kg at 135hp from a fireblade = 260 bhp ton.
Yes, I am bored.
Steve.
I suspect Liam might have something to add with his 170hp 2.7 honda v6.
Dunc
posted on 5/4/02 at 09:38 AM |
Nissan 200SX, 198 Bhp, 600kg car, 330bhp/ton But it only revs to 7250rpm Jon
Yes I am bored too.
PS. Did any of you see Driven on ch4 last night? Lotus Moded xr4x4 vs a Max Power Mag moded Cav Sri.
interestedparty
posted on 5/4/02 at 10:03 AM |
Thanks for the info, Gentlemen. Anyone interested in Ford V6 performance tuning might like to have a look at
http://www.chevroletls1.com
John
stephen_gusterson
posted on 5/4/02 at 11:07 AM |
Yep, I saw 'Drivel' last night.
Cant quite understand how the cavalier came out winner. It was beaten by the xr4x4 on the acelleration test, but came 1 car length ahead of the
hustling ford in a short race. The ford was attatched to its rear bumper!
atb
steve
Dunc
posted on 5/4/02 at 11:36 AM |
The Bently almost had the elise beat too. Maybe I'm going the wrong way, maybe I should go for the big weight big power. Hmmm maybe not.
I like the v6 sierra's. I ran about in a 4x4 one for a couple of weeks there till I managed to break a conrod last weekend. Took a day to strip the
front suspension and take the engine out. Contemplated putting it back together for a couple of months till the tax runs out but decided to strip it
early. Great traction and low end grunt but found the sierra understeered horrendously, hopefully in a locost it'll be sorted. Get the Max Power lads
to get it 'SORTED'.
Sorry, back to the subject before I get abuse from Wally. What would be the best format to post drawings. JPGS lose some of the data, would WMF be any
good?
stephen_gusterson
posted on 5/4/02 at 01:00 PM |
good?
GIF format isnt lossy, nor is a BMP file - but you could ip it to save on the massive space.
Another way is to download Acrobat Writer from Kazaa (freebe hacked version) which will save to a pdf document.
Dunc
posted on 5/4/02 at 01:49 PM |
Sorry, I didn't mean data loss I meant resolution. Sometimes it can be hard to read numbers and text on jpgs from drawings. WMF seam to scale it and
it can be read into word.
jcduroc
posted on 14/5/02 at 07:19 PM |
Hi Dunc
I'm interested in those drawing too but DEFINITlY NOT in 3D CAD.
Can you make them .pdf; anyone can download freely Acrobat Reader from www.adobe.com to read .pdf files.
Joćo
Dunc
posted on 14/5/02 at 09:43 PM |
Ok J I'll give it a go. If Boss Man manages to get the file thingy up and running I can put stuff there. I'm still trying to sort out all my cad
files, have over 3000, so its taking a lot longer than I'd expected.
punker
posted on 15/6/02 at 10:30 AM |
dunc
very interested in 3d models of engines and gearboxes as im modeling my IRS chassis in solidworks at the mo and would be very helpful.
Ben
4x4xFUN
posted on 20/8/02 at 10:22 AM |
4x4xFUN
posted on 20/8/02 at 10:24 AM |
I've just seen the postings by DUNC about the cad diagrams of the 2.9 cologne. I would really really love to get my hands on them for use in Autocad
2002 on a 4x4 one off I'm working on. If DUNC is out there or anyone knows where I might find him please get in touch, cheers.
josty
posted on 20/6/04 at 10:26 PM |
Hello Dunc,
I'm interested in CAD files of de 2.0i dohc sierra engine. Which program has been used?
