fleetwood
| posted on 10/11/05 at 08:32 PM |
Fuel filler necks
Does anybody know or have any experience of the legal side of fuel filler necks. Ive read the manual and can't really see anything. Can a motor
bike style filler cap on the top of the tank be used to save having to go out through the body side. I've got a bit a space problem and seems
to me that the easiest way is to fill the tank directly from the top. any thoughts any body?.
RazMan
| posted on 10/11/05 at 10:19 PM |
I don't see a problem with that. I'm not sure what Mr SVA would say but I would imagine that as long as there is no risk of fuel overspill
accumulating inside the bodywork he will probably think its ok too.
*edit* This thread might get moved into the SVA/Legal section
[Edited on 10-11-05 by RazMan]
Raz
bob
| posted on 10/11/05 at 11:08 PM |
If running an engine with a cat i believe you need an unleaded restrictor in the neck.
If no cat then pipe and cap,i had locking boot over my cap so avoided the cap lock.
| posted on 11/11/05 at 12:40 AM |
Our's is on the top of the boot box, so:
LARGER PICTURE
Restrictor needs to be secure inside the filler neck.
Mark18
| posted on 11/11/05 at 10:57 AM |
Where'd you get that bob? I'm looking for an cap and a bit of aluminium tube to weld to the tank.
Mark
bob
| posted on 11/11/05 at 03:20 PM |
Mark
I purchased the filler neck from thinkautomotive,its a mocal ali neck with a threaded cap and cost about £12 if i remember right.
www.thinkauto.com
