Author: Subject: Cheap Compressors
stevebubs
posted on 11/12/05 at 07:22 PM Reply With Quote
Cheap Compressors
NoTool Compressor Link
Any good?
the_fbi
posted on 11/12/05 at 07:44 PM Reply With Quote
Personally I'd go for http://www.transtools.co.uk/150022comp45ltr.htm
Its 3HP and has twin outlets.
Only £10 more than the 2HP eBay one (delivered) as delivery is free from Transtools over £50.
zzrpowerd-locost
posted on 11/12/05 at 07:54 PM Reply With Quote
50 litre compressor tend to be useless, i had one in my work van, wouldnt blow the skin of a rice pudding! Changed it to a 100 litre one
Now that would even drive a 3/4" air gun
Hose's that tend to come with the cheap compressor are useless aswell, not big enough for impact wrenches ect. You want a minimum of 8mm(5/16" bore hose, 10mm(3/8) is ideal for everything but the bigest of air tools
[Edited on 11-12-05 by zzrpowerd-locost]
stevebubs
posted on 11/12/05 at 08:09 PM Reply With Quote
Surely this is more down to the power of the motor?
The extra capacity will give you:
longer time to come up to pressure
longer to run before the motor cuts back in
Not had my SIP 2/50 run out of puff on me yet...althougu it you're looking at running intensive tools then a 3hp motor is desired.
rayward
posted on 11/12/05 at 08:29 PM Reply With Quote
depends what you intend to run, the CFM is what to look at, but many manufacturers dont list the details.
ideally you want minimum of 8CFM, which will drive air drills, sanders, and a small shotblast cabinet if you wanted, as well as the usual spray guns, tyre inflators etc.
the one from transtools looks pretty good value.
Ray
[Edited on 11/12/05 by rayward]
albertz
posted on 11/12/05 at 08:46 PM Reply With Quote
Coincidentally i was on the phone this very morning trying to order that 'Valley' compressor that
'the_fbi' linked to. I thought it looked a good spec for the price. Should do most of what i want it for.
Funny/odd/annoying thing is i contacted them through Ebay and was quoted 25 for delivery so glad you pointed out free delivery through their own website
the_fbi
posted on 11/12/05 at 09:06 PM Reply With Quote
Yea, can't quite work out how/why they are charging more through eBay, although clearly there are fees for eBay when there's not for their own website.
The 100L vertical would be my weapon of choice, but I can't justify the extra cash just for more volume and a smaller footprint.
dave dickson
posted on 11/12/05 at 10:07 PM Reply With Quote
This one looks like a much better deal..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7569885850&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1
Its close to reserve now.
joolsmi16
posted on 11/12/05 at 11:23 PM Reply With Quote
compressor
screwfix do a 2hp 50ltr for £100, I have a 3 hp 100ltr and only struggles when my 1/4" die grinder on full, spraying never found a problem.
zzrpowerd-locost
posted on 12/12/05 at 11:38 AM Reply With Quote
100l struggling with 1/4" die grinder
Something amiss there then?? do you run it at full pressure? i used to turn mine down to about 90psi on the regulator and it ran great! That was on the 50L one, 100L one used to wee it!
[Edited on 12-12-05 by zzrpowerd-locost]
zzrpowerd-locost
posted on 12/12/05 at 11:48 AM Reply With Quote
Probally, but used to last ages before the motor cut in!
The 50l one was shite, would just drive 1/2" impact gun, but wouldnt undo anything! Going to bigger hose made abit of difference but ports ect were just too small!!
One thing to mention, if you indend to use the likes of impact guns, or owt that doesnt need the air reducing, put a coupling with a desent thouput straight into the air tank!
Normally have a bung in one end with 1/2" female thread. Can get a pcl coupling with 1/2" male thread on it! With 10mm(3/8) hose you wont have much trouble!
posted on 12/12/05 at 02:14 PM Reply With Quote
The FAD is what to look for (free air delivery) as it is more relevant, usually it is about 2/3 of the CFM. Netto had the same spec compressor a couple of weeks ago for £69.99.
ADD
posted on 7/1/06 at 09:40 AM Reply With Quote
I realise this thread is a little old but I need to ask. I bought a 3hp 150ltr SIP compressor off of ebay. It will run a small sand blast gun but has no puff for any tools. I was told that the commpressor isn't man enough for tools. Is this right? If not then what is the best thing to cange to getting it working properly?
posted on 7/1/06 at 10:12 AM Reply With Quote
The pump
Is it belt driven or direct drive, oil or oilless. What tools do you want to run? I have a 3hp 50 litre which will run most things but die grinders and cut off saws use masses of air so there's a lot of waiting time. Nailers, riveters and wrenches are no problem though. Spraying uses lower pressure so the tank lasts longer. The tank size is only storage and shouldn't affect the working pressure, just the time it takes to fill the tank and the running frequency of the pump. Do you run through a pressure regulator or straight from the tank, your reg could be faulty.
posted on 7/1/06 at 10:32 AM Reply With Quote
i was looking at one of these the other day, as my current compressor is a little inadequate - its a 7cfm/25L one, and maybe 1.5hp, trying to turn an air cutoff and a die grinder! I havent researched enough to decide whether i should get one big one or another small one to pair up.
ADD
posted on 7/1/06 at 12:04 PM Reply With Quote
Its direct drive with oil, I want to run grinders, snips, riviters ect. I do run through a pressure regulator and through a 40ft length of hose (dont know the dia off top of my head). Is it possible to run direct from the tank? Isn't that a bit dodgy?
posted on 7/1/06 at 04:16 PM Reply With Quote
Try a shorter length of hose you will get pressure drop due to length and small bore.
posted on 7/1/06 at 04:59 PM Reply With Quote
my 'dream hose' is one of those self winding ones, on a reel on the wall 1/2 inch bore ideally.
The hose makes a terrible difference to my tools, when you stop using them you can hear air moving into the hose for a second or so afterwards, as the air catches up.
posted on 7/1/06 at 05:43 PM Reply With Quote
What I mean is do you run through the regulator on the tank outlet. I have put another connector on mine to run straight from the tank and I use a trap/regulator at the end of the airline near whatever I'm doing. I have various sizes of hose and I don't notice any difference in performance with any of them, the air runs ar 150psi to wherever the hose ends and the reg cuts it down from there. I don't have a "dream hose" but find rubber ones are more manageable in lower temperatures and I also find tools ice up easily in the present conditions even with a trap fitted. My longest hose is 20ft as I find it easier to move the compressor than drag a hose round whilst tripping over obstacles.
ADD
posted on 7/1/06 at 06:03 PM Reply With Quote
Yes I do run through the regulator direct from the tank. I will give it a go the way you suggest.
