Author: Subject: Using Hammerite Paint on the block..OK?
RichardK
posted on 18/12/05 at 01:19 PM Reply With Quote
Will Hammerite Smooth paint be ok on the engine block and head? Has anybody tried it?
Rich
Gallery updated 11/01/2011
darrens
posted on 18/12/05 at 01:22 PM Reply With Quote
I have used hammerite on a Pinto engine block before with no adverse effects.
posted on 18/12/05 at 02:39 PM Reply With Quote
You can get proper engine paint from Halfrauds for a few quid - works very nicely, with no risk of flaking, blistering, and so on. Easy to apply, as long as the surface is de-greased properly.
piddy
posted on 18/12/05 at 05:49 PM Reply With Quote
Yes Hammerite works well on the head and block.
A bit of a pain to cover though.
cornishrob
posted on 18/12/05 at 06:41 PM Reply With Quote
i used hammerite spray ontop of VHT as a primer on my calipers when i had a celica GT4 and they didn't even consider peeling. They got rather hot too so i would say it would be fine.
posted on 19/12/05 at 11:00 AM Reply With Quote
it will be ok. you need to ensure the surface is spotlessly clean as any grot underneath will cause bubbles and flaking.
NS Dev
posted on 19/12/05 at 12:28 PM Reply With Quote
Yep, will work fine.
Incidentally the best paint that I have found for blocks is industrial floor paint (or just garage floor paint bought from B&Q)
looks businesslike in grey or brick-red and is plenty heat resistant enough, as well as being extremely tough stuff.
Gernster
posted on 20/12/05 at 09:27 AM Reply With Quote
yep, i used in on A series & CVH blocks with no problems, just make sure you leave it 48hrs to dry, otherwise it bleedin stinks when you start it up!
[Edited on 20/12/05 by Gernster]
