RobBrown
| posted on 10/4/02 at 11:36 AM |
Engine doesn't quite fit
I recently bought an IRS chassis from Locost Ltd. and have just lifted my 1.6 Pinto engine, from a sierra, into the engine bay.
I have found that I cannot reconnect the alternator as it is impeded by one of the front chassis struts. Has anyone come across this before, and has a
solution.
The guys at Locost had asked me what engine I was putting in, and new it was a Pinto. Surely the engine bay should have been big enough.
Any advice would be greatly appreciated
| posted on 10/4/02 at 12:12 PM |
quote: I have found that I cannot reconnect the alternator as it is impeded by one of the front chassis struts. Has anyone come across this before,
and has a solution.
Try Les Newell's site, at this address:
http://www.lnewell.free-online.co.uk/engine_installation.html
He has a few pictures of his alternator installation about half-way down the page, plus some drawings, and he was very helpful to me when I was
thinking of using a Pinto.
(I then went and had a lie down, and the feeling went away... )
stephen_gusterson
| posted on 10/4/02 at 07:53 PM |
quote: I recently bought an IRS chassis from Locost Ltd. and have just lifted my 1.6 Pinto engine, from a sierra, into the engine bay.
solution.
If you are building a locost, thats just a tiny problem. I had to move my alternator and power steering pump on my v6 ford. They are mounted different
places depending on year etc.
atb
steve
RobBrown
posted on 10/4/02 at 08:46 PM |
Thanks for the link to Les Newells site. This looks like the way I need to go.
Rob
James
posted on 15/4/02 at 10:11 AM |
atb
steve
When moving the alternator etc. is it merely a case of changing the angle at which it sits (maybe with a new bracket) and using a shorter/longer belt
to compensate?
If this is the case, and I'll need the belt from another car, are belts usually similar width so it's easier to find an alternative or do you need
to hunt down one that uses Ford width aswell as it being the right length?
Did that make sense to anyone? If not I'll rewrite in English!
Thanks,
James
stephen_gusterson
| posted on 15/4/02 at 07:06 PM |
[quoteatb
to compensate?
Thanks,
James
I moved mine to the other side of the engine.
There were convenient holes in the block, and I made a 'pivot bar' out of inch rhs and some 3mm bits of plate - not that hard.
Make sure that you dont do something (impossible?) like drive the laternator wrong way round!
I got belts from www.farnell.com
look under drive belts and/or fenner.
They do lots of different sizes, approx 40mm or so increments.
If you cant find it on the site, shout. They are cheap, about 3 quid each. Min order 10 quid tho.
