Author: Subject: Zetec engine mounts What do you think ?
big_wasa
posted on 13/1/06 at 07:52 PM Reply With Quote
Made my engine mounts any one got anything good or bad to say about them ?
The near side item( Y shaped) is made from 2mm wall 1" rhs and the plate is 5mm and mount in middle is for the gearbox.
Thanks warren....
graememk
posted on 13/1/06 at 07:56 PM Reply With Quote
there better than mine if that helps
jambojeef
posted on 13/1/06 at 11:21 PM Reply With Quote
Not having much experience of the loads placed on the these Id say from a purely aesthetic standpoint they look really nicely fabbed and finished.
Nice one!
Geoff
gazza285
posted on 14/1/06 at 12:06 AM Reply With Quote
Why have you ground the welds? Something to hide?
muzchap
posted on 14/1/06 at 02:44 AM Reply With Quote
Hi Big Wasa
They look good! :-)
I'm interested in your 'Y' mount - what bits of the engine is it bolting to?
I'm trying to 'trial' fit my engine this weekend - completely ran out of time last weekend.
I notice you're only down the road in Spalding :-) I'm in Pete-bog-horror..
Murray
Danozeman
posted on 14/1/06 at 09:56 AM Reply With Quote
They look good Wasa. Kinda similar to my GTS ones but different if u know what i mean.
engine mount
engine mount
Dan
big_wasa
posted on 14/1/06 at 11:27 AM Reply With Quote
Gazza...
Only ground one weld (yellow) and that was an after thought to round it over. The white arrow shows where I ground the mill of before welding and a quick clean after.
Just wondered if they were man enough for the job ?
big_wasa
posted on 14/1/06 at 11:47 AM Reply With Quote
Will post a pic later Murray as im about to do another test fit for somthing elts..
stevebubs
posted on 14/1/06 at 02:18 PM Reply With Quote
You can see my original mount below which was man enough until one of the bolts into the block came loose and dropped out...at which time the plate by the block started to warp horribly. Have since replaced the entire mount with one in the shape of a Y very similar to yours but with a large plate at the front which uses all 4 tapped holes.
Zetec Water Pipes
Zetec Water Pipes
stevebubs
posted on 14/1/06 at 02:19 PM Reply With Quote
BTW, I had to tap the holes halfway down the block (the ones in use above) ?
andyharding
posted on 14/1/06 at 06:40 PM Reply With Quote
Free to a good home:-
O/S Engine Mount
O/S Engine Mount
big_wasa
posted on 14/1/06 at 08:50 PM Reply With Quote
near side
big_wasa
posted on 14/1/06 at 08:51 PM Reply With Quote
off side..
Sorry dont know how to stick to pics on one post ?
big_wasa
posted on 14/1/06 at 09:00 PM Reply With Quote
cheers all
gazza285
posted on 14/1/06 at 09:09 PM Reply With Quote
Look well up to the job.
