Ian D
| posted on 19/1/06 at 09:23 PM |
Zetec Engine identification
I have Zetec which im trying to identify. I bought what I thought was a 1.8Zetec with a Aluminium top marked DOHC 16V
Stamped on the block low down on the exhaust site at the rear is NBO 4481. Its badly stamped and uneven.
I also have in the cast above the water pump on the Exhaust side
928M
6015
CD
Does this make any sense to anyone. Or am I looking in the wrong place. I have looked on the Toynes site which was very good but does not help me
here.
Ian
ecosse
| posted on 19/1/06 at 09:35 PM |
You can have a look here but the numbers you have don't seem to match any of those
listed!
Alex
Ian D
| posted on 19/1/06 at 09:39 PM |
Alex
Im going back to have another look. I m looking in the right place but I appear to be missing the last 3 digits to
Ill check the first bit again to see if im reading it right.
Ian
davidwag
| posted on 19/1/06 at 10:19 PM |
There should be a large cast 16,18 or 20 in the side of the block.
perksy
| posted on 19/1/06 at 10:41 PM |
quote: Originally posted by davidwag
Yep, you should find this on the Intake side of the Engine Casting
Schrodinger
| posted on 20/1/06 at 09:34 AM |
Just got this from another useful site
http://www.toyne.org.uk/kit-car/zetec.html
follow the link to The Zetec where it gives some useful info on the various engines and this below is in a more useable format
Do you have a photo of the engine as I have seen a number of DOHC engines sold as Zetecs when in fact they are the earlier 8V DOHC engines.
1.6 Litre Engines (1597cc - Phase 1 & 2)
Code Standard Power Standard Torque Vehicle
L1E
L1H
L1J 90 PS @ 5500 134 Nm @ 3000 Escort 1.6
L1F
L1J 88 PS @ 5250 138 Nm @ 3500 Mondeo 1.6
(To 05/98)
1.6 Litre Engines (1598cc - Phase 3)
L1N
L1Q 88 PS @ 5250 138 Nm @ 3000 Mondeo 1.6
(05/98 - 05/01)
1.8 Litre Engines (1796cc - Phase 1 & 2)
RDA 105 PS @ 5500 153 Nm @ 4000 Escort 1.8
RKC 115 PS @ 5500 159 Nm @ 4500 Escort 1.8
RQB 130 PS @ 6250 162 Nm @ 4500 Escort 1.8
XR3i and GTi
RKA
RKB 112 PS @ 5750 158 Nm @ 3750 Mondeo 1.8
(To 05/98)
1.8 Litre Engines (1796cc - Phase 3)
RKF
RKH 115 PS @ 5750 159 Nm @ 4500 Mondeo 1.8
(05/98 On)
EYDA
To
EYDH 115 PS @ 5750 158 Nm @ 3750 Focus 1.8
2.0 Litre Engines (1988cc - Phase 1 & 2)
NGA 132 PS @ 6000 180 Nm @ 4000 Mondeo 2.0
(To 05/98)
2.0 Litre Engines (1989cc - Phase 3)
NGB
NGC 130 PS @ 6000 180 Nm @ 4000 Mondeo 2.0
(05/98 On)
EBBC
EBBD
EDBA
EDBB 125 PS @ 6000 180 Nm @ 4000 Cougar 2.0
EDDA
To
EDDG 135 PS @ 6000 180 Nm @ 4000 Focus 2.0
regards
Keith
Suffolk
[Edited on 20/1/06 by Schrodinger]
bob
| posted on 20/1/06 at 10:17 AM |
Engine numbers are stamped along the edge where the bellhouse of the gearbox mates,this is close to the crank position sensor.
Ian D
| posted on 22/1/06 at 01:31 PM |
I have found the same coding on the head with the RDA code.
Im going to try and see if there is a code verticaly stamped by the sensor. Mine is horizintally stamped where the block meets the sump.
I do have a large 18 cast into the block.
Looks likea call to Ford tomorrow.
Thanks for all your help.
scotty g
| posted on 22/1/06 at 02:09 PM |
As Shrodinger says, the earlier DOHC engine can be mistaken for a zetec, with 16v written on it, it could be from the Escort RS2000 or from the
Scorpio as they both used a 16v version of the older engine.
If this is what you have then do not despair as they are making quite good money at the moment, i have seen them selling for more than a 1.8 zetec.
Schrodinger
| posted on 24/1/06 at 12:09 PM |
If you have the engine number you can tell from that what year the engine is and that may help identify the engine.
Keith
Suffolk
stevebubs
| posted on 24/1/06 at 05:40 PM |
Does it look like this...
i.e. very slopey cam cover? If so, then it's not a zetec....
Ian D
| posted on 27/1/06 at 07:13 PM |
Guys,
Thanks for all your help. I faxed the code off to Ford and they have confirmed its a 1992 105PS ZETEC manufactured in January.
Hope this satifies the SVA man.
Why my code is written horizontally, who knows. Lte hope it starts.
