piddy
| posted on 24/1/06 at 06:26 PM |
zetec plumbing
Hi.
I'm at the point of plumbing the Zetec in my car.(Velocity)
I was just wondering how other had done this. Brought a kit like westfield sell.
or used hoses from various tin tops.
[Edited on 24/1/06 by piddy]
muzchap
| posted on 24/1/06 at 06:29 PM |
Hehe - it might help with an 'L' in the title ;-)
I'm at the same stage and www.zetec-cat.co.uk is a good reference.
If it was me - I'd pop down to Hal-Frauds and purchase some bendy pipe - work out all the angles and where the pipeworks going for YOU - then,
if you have the money swap some of it for some decent hose - Samco etc..
There are plenty of configurations for the Zetec - some use a water rail, some don't.
Good luck - I'll be checking back to see what advice you get ;-)
M
bob
| posted on 24/1/06 at 06:32 PM |
http://www.emeng.gentlyhosting.co.uk/Cooling/CoolPaper.htm
Plenty of cooling/plumbing info on this site
muzchap
| posted on 24/1/06 at 06:39 PM |
nice one Bob - that was another link I was scrambling around to find ;-)
Good work
zzr1100rick
| posted on 24/1/06 at 06:43 PM |
this might help no its not my pick
bob
| posted on 24/1/06 at 06:53 PM |
Good work
Cheers I have my uses,not many i must admit but a few.
The site has some very good info on a variety of zetec plumbing,and the added bonus of dimensions and part numbers too.
The whole site
zetec
| posted on 24/1/06 at 09:13 PM |
Save your money and don't use a water rail they don't work correctly.
Plumb the engine as it was designed to be done and it warms up correctly, use the Ford thermo housing. Big outlet to the top rad inlet. Two small
outlets connect using "t" connectors in the bottom hose between bottom rad outlet and water pump. Connect an expansion pipe with another
"t" into one of the small pipes going to the bootom hose. Tiny pipe in the top of the housing to the small connector on the expasion tank.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
muzchap
| posted on 24/1/06 at 09:35 PM |
Hi Zetec.
I checked your pics - but still confused about how to route the pipes :-)
Can you please explain in IDIOT PROOF terms for me!
I'm LEMSIPPED up here and brain is cloudy with flu...
M
lsdweb
| posted on 24/1/06 at 10:07 PM |
I've got all the hoses left from my Zetec install - Polo rad and Raceline water rail - all Samco and aluminium tube if you're
interested.
It's a myth that the Water Rail's don't work - if you have no space at the rear of the block you have little choice apart from
making your own!
Have a look here and
here
(Shown on the Escort rad but I changed to the Polo rad with the same hoses)
Wyn
[Edited on 24/1/06 by lsdweb]
givemethebighammer
| posted on 24/1/06 at 11:00 PM |
correct, my raceline water rail works fine. Even better that it was a cheap find (ebay if I remember). I think retro ford do one for a reasonable
price (advertise in PPC).
zetec
| posted on 25/1/06 at 06:42 AM |
The raceline unit I'm sure does work fine but why spend £150 quid when the Ford unit fits and works as the cooling system was dsigned. It allows
coolant circulation around the head during warm up.
Plumbing goes like this...
Exhaust side 32mm connection straight to rad top connection.
Exhaust side 18mm connection to a "T" piece in the bottom hose.
Inlet side 18mm(ish) connector to another "T" in the bottom hose.
Top small 8mm connector to the small connection found on the neck of most expansion tanks.
Bottom rad connection to the water pump. Tiger do a neat little ali pipe with two 18mm bosses welded to it to allow the two connections mentioned
above. I used a Samco reducing elbow on the pump to get it down to 32mm and in the direction of the bottom rad outlet.
The expansion tank connection can be run to a "T" in the 18mm pipe you are running from the inlet side connection.
Use the standard Ford thermostat (93 deg C I think), and a 15psi rad cap as the system tends to run at too higher presure for a 8mm cap.
lsdweb
| posted on 25/1/06 at 08:16 AM |
Hi Zetec
I agree - use the standard setup if it fits - in my case it didn't! The photo
here shows why.
Regards
Wyn
zetec
| posted on 25/1/06 at 09:27 AM |
Blimey you did get the engine back a long way...Arfe you ditching the zetec?
Browser
| posted on 25/1/06 at 10:38 AM |
Must admit, I thought the same, that's damn near mid-engined! My lump will allow me to keep the standard setup as I've got a Zetec/MT75
going in a Pinto/Type 9 chassis. This is a good thing 'cos I'm a softy and want a heater
stevebubs
| posted on 25/1/06 at 01:50 PM |
Hi Zetec.
M
This help... ?
  Zetec Water Pipes
stevebubs
| posted on 25/1/06 at 01:52 PM |
Top hose you can see goes to top of rad
Bottom of rad goes to water pump and has the lower hose from the thermostat housing T-ed into it.
muzchap
| posted on 25/1/06 at 02:12 PM |
Steve,
Cheers for that - I think I'm slowly getting it ;-)
I'll have a play around at the weekend - once I'm there looking at it - it should all make sense :-)
Murray
piddy
| posted on 25/1/06 at 06:20 PM |
Thanks chaps.
Most useful.
Lsdweb you have u2u.
Schrodinger
| posted on 25/1/06 at 07:29 PM |
Is this any help?
It comes from the site mentioned earlier
http://www.toyne.org.uk/kit-car/zetec.html
regards
Keith
Suffolk
lsdweb
| posted on 25/1/06 at 09:04 PM |
Hi All
I've had several U2U's about the bits. I've sold the rad, water rail and the car! All I have left is the plumbing bits which I was
hanging on to just in case I needed them for the new project. Sadly, the R1 engine has much smaller hoses.
I'll take some photos and post them to this site later.
Wyn
liam.mccaffrey
| posted on 25/1/06 at 11:26 PM |
i've got his rad!
and I'm ashamed to say that its still in the boot of my rover along with the manta gearbox, i just havn't had time to do anything
recently
Build Blog
Build Photo Album
lsdweb
| posted on 26/1/06 at 08:15 AM |
That's better than having it 'cluttering' up my shelves in the garage!!!
You've been quiet Liam - busy building the car?
Wyn
liam.mccaffrey
| posted on 26/1/06 at 06:17 PM |
trying to get the house build of the ground wyn (pun intended)
also i'm a bit pissed off with another project of mine so i'm throwing a bit of money at that at the moment
its repairing my lathe, im getting really annoyed with outsourcing jobs i coudld do myself if the lathe was 100%
still going to be using the emerald with the r1?
also i noticed you got rid of the astra dash too
[Edited on 26/1/06 by liam.mccaffrey]
Build Blog
Build Photo Album
lsdweb
| posted on 26/1/06 at 08:18 PM |
Hi All
Enclosed is a photo of the bits I have to fit the Zetec with Raceline water rail.
lsdweb
| posted on 26/1/06 at 09:52 PM |
Hi Liam
I can understand your difficulties with the build - been there! Our greatest problem was with our architect - absolute waste of space - I'm not
suggesting they all are though!
My project is driving me mad - loads of changes in direction - the chassis is now with a guy near Lampeter - he's ex Duffee / Darian so knows
his stuff! He's going to be doing all the fabrication of the backend of my Swift - he has a Radical in the workshop so there may be some
similarities when it's finished .
I'm hoping that when I get it back it'll be a simple job of bolting it all together, wiring, plumbing and setup. Yes, I'm planing on
running the R1 on the Emerald system. I think it'll be relatively easy to fit an external crank sensor - did I say the wiring would be easy?!
Regards
Wyn
