ianr
posted on 6/2/06 at 09:33 PM |
Engine Sparks
I have tonight gone to try and turn my car over and have tried till the battery is flat starting her. Then when that went flat i tried to push start
with my wife in the driver seat. Then after several pushes and the last one with the handbrake off we decided to jump start. Once started though it
sounded very rough and i could see sparks coming out the exhaust side of the engine.
Will this be because i have excess fuel in the car or my leads HT leads are bad.
This has not happened before but is the longest i have tried to start the car.
posted on 6/2/06 at 09:42 PM |
you would have to give more details about the sparks - where from exactly? Localised or spread out?
ianr
posted on 7/2/06 at 01:18 AM |
It is coming out from where the exhaust attaches to the engine. The engine is a crossflow. Seem to be all from the same place.
posted on 7/2/06 at 06:52 PM |
Sounds like the exhaust manifold gaskets are leaking, try tightening the manifold nuts . If that doesn't cure it replace the gaskets. What
manifold are you using? used a lolocost one on mine and had a job sealing that to the head, in the end I took it off and separated each flange because
of distortion, sealed no problem then . Obviously this doesn't rectify your bad starting.
ianr
posted on 7/2/06 at 06:58 PM |
I did not build the car, so not sure although looking at is is not the greatest fit. Starting is an issue that is a separate problem that i will solve
when i get some Spare cash
HAL 1
posted on 11/2/06 at 12:22 PM |
engine sparks
Hi
not sure if this is relevant but recently had trouble with rough running, difficult starting so cleaned plugs etc tried jap/german plugs no luck,
champions, fired up first time purred like a kitten
Good luck
ianr
posted on 11/2/06 at 06:23 PM |
The exhaust is missing a screw to the manifold and there is space between the exhaust and manifold , which maybe the cause of the rough engine, The
plugs do look a little dark so may be wise to replace.
posted on 13/2/06 at 09:41 AM |
crossflow; yep, got one of those.
the spark plugs are on the exhaust side.
I thought perhaps it could be flashes of light as the mixutre burns but having thought a bit more, that should not be possible as the mixsture has
burnt once the eaxuahst valves have opened to let the gases out.
... but it could be that a piston is not firing and the mixture is burning in the exhasut manifold.
Not having seen it I would have thought is would be quite easy to localise the source.
You say you have gaps between the manifoled and head ... hmm. that is not good. you could temporarily show some exhasust past into the gap to seal
them to see if that helps; if it doesn't, then more likley it is ignition. (NB: be careful when doing this as you do not want to drop paste in
toe the engine via the head).
More likely it is ignition - are you leads bad so you hare getting arcing to the block? Has one of you leads touched and melted on the manifold so is
arcing? By remving one lead at a time, you should be able to find out the cylinder causing the problem.
To help you narrow down the origin, run the engine whgen it is dark - easieer to see.
DarrenW
posted on 13/2/06 at 11:39 AM |
I had similarish experience when first getting mine running. Suggest fitting exhaust manifold properly. Make sure plugs, points etc are all good.
Recheck timing, plug leads in corretc order etc. Recharge battery and have another go. You cant be far off if it was running in a fashion. Just make
sure the basics are all covered first.
If you still have problems tell us what the spec is (ignition type, carb type etc) and take advice from there.
Sam Williams had some problems so have a look for his post - maybe some good pointers for you.
ianr
posted on 17/2/06 at 08:07 PM |
I have just come back from holiday so the car had to be tucked up in the garage for a while.
But my plan A is to try and buy and fit the missing exhaust manifold screw then tighten to remove all gaps then try again
to see if the same thing happens
