IainB
| posted on 1/3/06 at 09:41 PM |
ARRGHHH! Bike Carbs!
Yes its that time again, clueless idiot needing help with newly aquired zx6r carbs and manifold.
Got the carbs all plumbed but no joy when cranking the engine over. Deff have a spark and timing is deff right.
I am running using the original re circulating fuel system with carbs drawing from a in line 'T' section.
Carbs seem to be getting plenty of juice (maybe slightly too much) and easy start doesnt seem to work either.
Help!
Engine is 1500 sohc fiat x1/9 and carbs are ZX6R rejetted to 160 each.
Is it possible to pump too much fuel into carbs? Have now ordered ZX6R fuel pump so that will put my mind at rest about pressure. Anything i can do in
the mean time?
Much appriciated,
Iain
http://s43.photobucket.com/albums/e365/IainB1986/
gary gsx
| posted on 1/3/06 at 09:49 PM |
What fuel pump are you running??
IainB
| posted on 1/3/06 at 09:59 PM |
its a small mechanical jobby. Used to run a continuous system, tank - pump - carb - tank....
that was with the old weber so iv just put a T junction where the old carb was and fed the new carbs with that.
Iain
gary gsx
| posted on 1/3/06 at 10:04 PM |
Have you tried clamping the fuel line (brake pipe clamp) slow fuel/pressure down see if it will fire then
Just waiting to be taken down lol
daviep
| posted on 1/3/06 at 10:06 PM |
If it won't fire on easystart then you obviously have an ignition problem, have you taken a plug out to see if you have a spark?
[Edited on 1/3/06 by daviep]
eddymcclements
| posted on 1/3/06 at 10:23 PM |
If you've been overfuelling while trying to start, it's possible that the plugs could be very wet with petrol and tracking instead of
sparking. Do you have a spare set of plugs you can try?
Eddy
[Edited on 1/3/06 by eddymcclements]
joolsmi16
| posted on 1/3/06 at 11:33 PM |
Have a rethink wait for the bike fuel pump to come as I think they are all Mitsubushi and will have a self regulator in so then fuelling will not be
an issue and hopefully it will fire.
Failing that take onboard what the rest of the members have already mentioned.
oliwb
| posted on 2/3/06 at 08:29 AM |
Reckon jools is right.....wait 4 the bike pump to turn up, only needs a little bit too much pressure in the fuel line to flood em....see u at t
wknd....l8r my man...Oli.
Surrey Dave
| posted on 2/3/06 at 09:39 AM |
Pressure
You only need 1 - 2 lbs fuel pressure, you can use a bike pump , or a fuel regulator set at that level.
Any moree pressure can open the fuel valves in the float chamber and flood .
Have you mounted the carbs at a similar angle as when they where used on a bike?
IainB
| posted on 2/3/06 at 11:25 AM |
cheers guys,
had anoth4er go this morning, still no joy. Its trying to fire on its own and sometimes on easystart, tho that seems to flood it. Il hold tight til
the new pump comes and how she likes that.
Its a Bogg Bros manifold so yeah the bowls seem to be sitting pretty level.
Iain
Ps. Does Easystart work on lazy sleeping flatmates?
MrSandMan
| posted on 2/3/06 at 07:46 PM |
Mechanical Pump
My Pinto uses the standard mechanical pump with R1 carbs. No problem with flooding here. My only problem is poor starting when cold but I think this
is due to a poor spark.
