Author: Subject: Source of breakpipe clips?
Bluemoon
posted on 29/3/06 at 09:57 AM Reply With Quote
Hi All,
Looking for a source of breakpipe clips, not P clips, but the ones were you can push the pipe on and off after fixing the clip to the chassis, i.e a Y clip?
Dan
DarrenW
posted on 29/3/06 at 10:09 AM Reply With Quote
i couldnt get away with them. If the pipe wasnt nice and straight they tended to pop out. I used the cable ties that have the xmas tree style fitment - ie drill hole, push the fastener into the hole and secure pipe with the integral cable tie. These also space the pipework away from the chassis as well. Passed SVA with no comments.
I tried to use the cable ties bases that you can secure with rivet / screw onto the chassis as well but found they snapped frequently (heavy handed!!!) before i was happy with the security.
Does this help?
posted on 29/3/06 at 10:19 AM Reply With Quote
Easy answer - make your brake pipes straight!
Tangerine Scream
posted on 29/3/06 at 10:35 AM Reply With Quote
I sourced my brake pipe clips from Europa. Really awful to work with though as DarrenW said :-(
Ended up using stainless P clips which ISTR were cheapest from RS components.
Bluemoon
posted on 29/3/06 at 10:43 AM Reply With Quote
Any more ideas..... It would be nice to be able to remove the pipes without having to drill the rivets from P clips etc.
DarrenW what do you mean by Xmass style clips?
[Edited on 29/3/06 by Bluemoon]
DarrenW
posted on 29/3/06 at 11:02 AM Reply With Quote
Difficult to describe in writing, but basically the cable tie has an integral barbed fastening that locks into a pre-drilled hole. They can be removed fairly easily by cutting them with stanley knife and replacing with new tie. If you want me to send you some samples iam happy to do that - just U2U me your address. Failing that i could try and take a pic. Im sure they will be available from most places that stock cable ties.
These are similar to what i used
http://www.hellermann.tyton.com/media/documents/studmount_ties.pdf
owelly
posted on 29/3/06 at 11:30 AM Reply With Quote
http://www.tifosi.homecall.co.uk/New%20products2.html
Any good??
http://www.ppcmag.co.uk
DarrenW
posted on 29/3/06 at 11:33 AM Reply With Quote
Ive just been home to get some more info for you. The parts i used are made by hellermannTyton, part number T505D6.HB6.
Similar to those in the link but the cable tie head is just above the button headed bit. i used them for brakes, fuel lines and cables.
HTH
Darren.
chrsgrain
posted on 29/3/06 at 12:14 PM Reply With Quote
I've used the single double and treble clips from Automec - link below if it works! I agree, not great to use, but if you drill a hole 1/2mm too small and then push them home with a small persuader (hammer) then they don't come out. I especially like the treble clips to hold 3 pipes side by side where they will be visible...
Chris
Automec brake stuff linky
posted on 29/3/06 at 12:25 PM Reply With Quote
I know the type I used to get them from LSUK
posted on 29/3/06 at 01:47 PM Reply With Quote
This from an Ebay supplier is much the same
http://cgi.ebay.co.uk/JAGUAR-10-X-BRAKE-PIPE-CLIPS-OE_W0QQitemZ4624809597QQcategoryZ10390QQrdZ1QQcmdZViewItem Rescued attachment black.JPG
Bluemoon
posted on 30/3/06 at 02:00 PM Reply With Quote
Hi Mark,
How many did you use? Had paying 20p each, seems a lot for a peice of plastic, I have got some plastic P clips but were 1p each!
Dan
[Edited on 30/3/06 by Bluemoon]
