Author: Subject: Crossflow Oil Pressure Sender sticking
posted on 6/4/06 at 12:22 PM Reply With Quote
I am still working towards SVA so don;t run the engine often but most of the time when I trun on the igntion, the oil pressure lamp does not come one. Tapping the oil pressure sender with a hammer fixes that.
So it seems the swicch is sticking.
Does this mean I need a new switch or can I revitalise the one I have by cleaning? (may be bunged up) .
posted on 6/4/06 at 12:28 PM Reply With Quote
If you take it out and look at the threaded end you may find a hole with mesh in it. If that's clogged up then maybe you could clean it.
If it was my engine, I'd ring Burton Power and get a new one (they're not silly money). It's always good to know that you've got oil flowing!
[Edited on 6/4/06 by David Jenkins]
