Author: Subject: crossflow temp & oil sender connection thread?
posted on 7/4/06 at 08:29 AM Reply With Quote
the waqter temp and oil pressure sender look very similar; about the same size and also appear to have a threaded rod sticking out; does anyone know the thread?
At the moment I have a push on connector but a nut and spring waster would be more secure. (all I know it is not a metric thread).
Chris_G
posted on 7/4/06 at 09:53 AM Reply With Quote
Oil sender thread is 1/4" NPT, not sure about the coolant one though but could be the same although I thought they were bigger??
Chris
[Edited on 7/4/06 by Chris_G]
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
posted on 7/4/06 at 10:05 AM Reply With Quote
I think he means the one at the other end - where the electrical connection is made. My oil sender used some rubbish USA size that I happened to have at home... some number size or other.
Everything else is UNC or UNF on the engine, so it'll be something along those lines...
DJ
theconrodkid
posted on 7/4/06 at 10:27 AM Reply With Quote
the thread is just used to grip the push on connector,dosnt need nuts
who cares who wins
pass the pork pies
posted on 7/4/06 at 10:44 AM Reply With Quote
yep I do mean ther other end; I haver a push on connector but a tag with nut wold be more secure.
some obscure usa connector sounds about right.
DarrenW
posted on 7/4/06 at 10:53 AM Reply With Quote
As far as i know it isnt a specific thread, as already stated basically a barb type affair to grip the push on connector. I replaced my senders and new ones had spade terminals but for the coil i cut the plugs off Sierra loom and grafted these onto my loom. Works a treat.
If you are concerned about them potentially falling off you could route and secure the loom in such a way that the plugs are better supported.
posted on 7/4/06 at 11:36 AM Reply With Quote
It's certainly a thread on my oil sender - I have a ring terminal held on my a bolt. However, my temp sender had a push-on connector (the replacement now has a Lucas spade connector).
If the push-on connector is reasonably tight then that's more than enough - in my case there's only 6" of wire hanging from it, in a slack loop.
