PerspexIt
posted on 27/3/03 at 05:43 PM |
Vauxhall/Opel to Ford adapters
i'm thinking about Vauxhall (Opel) 1.6 16v engine.
I saw the SBDEV web site:
http://www.sbdev.co.uk
Just sent an email for get a quote of the adapter.
Anybody know other Sierra box adapter manufacturers? And/or have an idea of the prices?
Regards,
-P
[Edited on 27/3/03 by PerspexIt]
Sparky
posted on 28/3/03 at 12:59 AM |
Unless you absolutely have to have a type 9, I've got an all alloy 5 speed Getrag out of a Manta 'J' series, along with the
prop, a very light flywheel and a quickshift mechanism.
I've got an inline alloy sump to fit your 16 valve lump too!
Let me know if you're interested
PerspexIt
posted on 28/3/03 at 07:44 AM |
Hi Sparky,
the problem is in my country will be close to impossible to find a Manta but it's full of rusty Sierras.
Send your box will cost me too much, i think.
Thank you anyway.
-P
rgv_stu
posted on 28/3/03 at 12:54 PM |
the manta box is a for a big block vauxhall
the 16v 1.6 is small block so needs a smaller box.
get one from sbd
Sparky
posted on 28/3/03 at 06:40 PM |
Stu, just to clear this up, this was a 1985 Manta 1800 OHC (same engine as the front wheel drive Cavalier) with the all alloy Getrag 5 speed box.
As far as I'm aware, the front wheel drive bellhousing patterns, including those for the 'J' series engine and the 16 valve engines,
are identical.
If I'm wrong, I apologise.
carnut
posted on 28/3/03 at 10:18 PM |
Try Caterham they used to run vauxhall to type 9 box. They will most likely keep bellhousing and all adapters for use as spare parts.
dutchsuperseven
posted on 30/3/03 at 10:33 AM |
Vauxhall/opel to ford
Try using a Omega 5-speeder. This box will fit 1.8/2.0 ohc engine. It might fit the 1.6 8v/16v. It's only for IRS aplication because it has got
a flange at the drive-shaft side ( so no length compensation for live axle). It's a alloy box, so it's light as well!
