jock
| posted on 12/4/06 at 08:40 PM |
capri rear end
hi i got my chassie of ebay by the book to fit escort rear end or cortina. dus capri axle fit .
big_wasa
| posted on 12/4/06 at 08:53 PM |
Yes with a small mod. The dimensions are on here some where if you do a search but you basically have to put a dogleg in the back bottom tunnel
rail.
| posted on 12/4/06 at 09:37 PM |
this dogleg will also slightly limit your choice of seat if you're not careful!
scutter
| posted on 13/4/06 at 05:54 AM |
I went the other way and removed a small amount of the web on the Diff. The theory being that the car's a lot lighter and won't put too
much stress on it .
  axle finally finished
ATB Dan.
Mark Allanson
| posted on 13/4/06 at 06:38 PM |
I found the input flange was the problem, not necessarily the webbing
