Krismc
| posted on 15/4/06 at 05:07 PM |
Zetec- type 9 connection!
When im connecting my zetec to my type 9 box, ive a few questions! (2 litre black top 1999v)
a) ive been told i need a dust plate? to stop the crap entering the box where from or do i have to make one!
b) i have no fixing bolts does anyone know what lenghts and threads i require?
c) i will need to shorten sump, not only from ground clearance but for starter clearance, this is sumthing behond my capabilities- can any one do this
or direct me towards sumone who can?
d) ive been told i need shorter bolts for the flywheel connection, should i use washers, cut down the originals or use some new shorter ones, if so do
they have to be a special grade!
thanks in advance, i know its a lot to ask!
DIY Si
| posted on 15/4/06 at 05:12 PM |
The dust plate is, I think, the plate that covers the bottom half of the bell housing. You may be able to buy one, but may be easier to make one out
of 16swg sheet. That's what mine'll be.
Fixing bolts are prob M10 x bugger only knows how long. Some of mine are 35mm, but some need to be 40-45mm. It's best to get bolts that are a
few mm long to ensure full thread connection.
Don't know about the other questions.
Dusty
| posted on 15/4/06 at 05:41 PM |
Pic of my dust plate below. Modified pinto one.
Bolts are M10 and 30 and 40 8.8 high tensile. Standard thread.
Flywheel bolts, use new standard ones from Fords for 2L or better 1.8 flywheel. I think 12.9 and a fine thread.
Krismc
| posted on 16/4/06 at 08:12 AM |
thats a big help cheers guys, so how thick is '12swg' ??
Dusty
| posted on 16/4/06 at 10:09 AM |
12 swg is 2.6mm. Can't measure mine anymore cos it's on but I don't think it was any more than 1.5mm from memory.
Krismc
| posted on 16/4/06 at 05:58 PM |
so i should get a sheet of 1-1.5mm ally and cut that shape out!!
oh well ill give it a try!
DIY Si
| posted on 16/4/06 at 06:29 PM |
Might be better to get 16swg steel sheet for the plate, It'll be cheaper to buy, and I'm not sure ally would be ideal for that
application. Could be wrong, but I've only ever seen steel ones.
Krismc
| posted on 16/4/06 at 06:56 PM |
i can buy ali from B and Q not sure where i get steel from!
Danozeman
| posted on 16/4/06 at 08:06 PM |
Steel would be better but you dont have to have the plate in. MInes going in without one tomorrow. You can modify the CVH one to fit if you can find
one..
As for the sump look up scholar engines. They do a chopped one for reasonable money.
What do you mean? Zetecs use standard zetec flywheel bolts. Fit new ones. They are a high tensile shouldered bolt and come with thread lock on
them. You shouldnt need to cut them down if its a zetec flywheel.
Dan
Krismc
| posted on 16/4/06 at 08:19 PM |
im using a lightened pinto flywheel and starter with a xflow clutch!
was told the standard bolts will lock up!!
Krismc
| posted on 16/4/06 at 08:24 PM |
Shortened sump is £180 + vat + delivery!
Pheew thats expensive for a cut and shut!! i need it done cheaper
Krismc
| posted on 19/4/06 at 07:43 PM |
...right went to ford 8 long and 2 short bolts for bellhousing was £3.50!
but i cant order auto ones unless i know which auto flywheel its from! any help??
