flak monkey
| posted on 19/4/06 at 07:14 PM |
Quick pinto question
Stupid question time...
I bought my pinto in bits, got it all figured out except one thing.
On the back of my pinto block is a big hole going into the water jacket. It would be behind the gearbox bellhousing once its bolted on i think. But
obviously theres not meant to be a hole there.
Should it have a core plug in? Or does something else belong in there? (i couldnt think of anything, and theres no fixing holes around the hole).
Sera
http://www.motosera.com
Mark Allanson
| posted on 19/4/06 at 07:17 PM |
If it is this 'hole', you will need a core plug
flak monkey
| posted on 19/4/06 at 07:19 PM |
Nope, its on the block behind/under the gearbox bellhousing, not in the head. Its fairly big, not a clue on size off the top of my head though.
I dont have any pics unfortunately, and the engines 100miles away.
[Edited on 19/4/06 by flak monkey]
Sera
Mark Allanson
| posted on 19/4/06 at 07:23 PM |
Now ACTUALLY read your question
answer is still the same though
flak monkey
| posted on 19/4/06 at 07:24 PM |
Thats the one.
Cheers Mark
Sera
Yes you need a cors plug, probably worth fitting a set, only pennies but will save a lot of hassle
BKLOCO
| posted on 19/4/06 at 08:20 PM |
Oops should have mentioned that
When I stripped the engine that plug was weeping so I took it out.
flak monkey
| posted on 19/4/06 at 08:23 PM |
Cheers Brian
I will yank all the old ones out anyway i should think and flush the block through, though it looks to be pretty clean anyway.
Sera
DarrenW
| posted on 20/4/06 at 08:32 AM |
he he he - thats the bugger that failed on mine at SVA and dumped dirty water into their brake rollers  Believe me its a sod to get to when
engine is installed (e-metalled for now until i upgrade at a later date.)
