Krismc
| posted on 20/4/06 at 04:03 PM |
Zetec- throttle boddies
if i bought this....
Mega Squirt ECU
this ...
Jenvay throttle boddies 50MM
and a manifold to suit, what else woulc i require for my blank stripped Black top zetec 2.0
muzchap
| posted on 20/4/06 at 04:08 PM |
Personally, I'd get bike throttle bodies and save your money on Jenveys!
You'll need
* MegaSquirt Engine Loom!!!
* injectors + fuel rail - GSXR 750 is good
for 200hp - so ya can keep them if ya
want
* wideband O2 sensor (purchase or
borrow)
* laptop
* Fuel swirl pot
* High pressure pump
Just helped mate get Pinto injected on bike TB's and running with wideband... its ace.. My zetec should be up and running in 2 weeks ;-)
Murray
[Edited on 20/4/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Krismc
| posted on 20/4/06 at 04:17 PM |
i would get bike throttle bodies but was told i wouldnt pass SVA!!! or should i say would be very difficult to pass!
[Edited on 20/4/06 by Krismc]
muzchap
| posted on 20/4/06 at 04:36 PM |
Er - how would bike throttle bodies stop you passing the SVA
who told ya that big load of bollox???
They are more than suitable for the job, if connected properly.
Somebody's having you on mate...
Krismc
| posted on 20/4/06 at 04:41 PM |
sorry it was just me getting confused, big-wasa has a set of bike carbs for sale i thought bike carbs/throttle boddies where all the same!?!
I would love to buy these from him but, if its a no no then i wont!
So where and exactally what do i require? and what are the best throttle boddies to use?!
Krismc
| posted on 20/4/06 at 04:44 PM |
and i can get a brand new set of jenveys with OMEX ECU for £1600!
what would the bike setup cost?!
JohnN
| posted on 20/4/06 at 04:49 PM |
So you missed this on
Ebay?
Bike tb alternative at half that price (also just missed - but make your own even cheaper)
here
Suzuki gsxr 600 tb's generally are around the £75 mark, so if you can make your own manifold, you're quids in
[Edited on 20/4/06 by JohnN]
Krismc
| posted on 20/4/06 at 04:57 PM |
dam, and double dam!
muzchap
Hmm Kris
You're confusing the issue here ;-)
Bike Throttle Bodies with Injection
Bike Carbs
I believe are 2 separate items.
I listed what you'd need for the first:
* MegaSquirt Engine Loom + Megasquirt
£200ish
* TB's + injectors + fuel rail - GSXR 750 is good
want
Around £100
borrow)
Loan is £20 ish (Bill Shurvinton)
* laptop
* Fuel swirl pot
£40 ebay guy makes em
£40 Ebay guy sells em
* Manifold
£200 ish
So budget for about £650 for the complete works
That's £1000 cheaper than Jenveys
Murray
Krismc
| posted on 20/4/06 at 05:02 PM |
sorry thought i may be confusing every body! ..forget what i said!!
To the above anyway..That sounds resonable, the only thing is i dont know which throttle boddies i need exactally...although you said the GSXR 750,
are the 600's no good as only ones on ebay at the moment!
I could get a manifold made by a friend of mine, do i just need the boddies no extra linkages or anything!
Krismc
| posted on 20/4/06 at 05:07 PM |
...what about these or are they too expensive.. @£140
http://cgi.ebay.co.uk/SUZUKI-GSXR1000-THROTTLE-BODIES-IDEAL-KITCAR_W0QQitemZ8056267171QQcategoryZ10534QQssPageNameZWD7VQQrdZ1QQcmdZViewItem
muzchap
Go for the 750's
The standard injectors are good for 200hp!!!
A decent BlackTop should make 178-182 at the flywheel (in standard trim) with Bike Throttle Bodies.
So well within the range.
Ring around some breakers - Ebay tends to be a little extortionate at the moment
Krismc
| posted on 20/4/06 at 05:12 PM |
spotted on ebay for £75 in good nick from a 2005 model, these ok??
Suzuki GSXR750
[img]http://i19.ebayimg.com/04/i/06/e2/38/f2_1_b.JPG[img]
does the year matter, and what should i ask the seller is with them, to make sure i dont need anything
stevebubs
| posted on 20/4/06 at 05:32 PM |
If you're getting a custom manifold made up and not respacing them for a DCOE manifold, then year doesn't matter.
Some have 2 sets of butterflies - just remove the second stepper-driven set and fill the holes.
All covered before...
http://www.locostbuilders.co.uk/viewthread.php?tid=20908
Krismc
cheers muzchap,
bought that set thanks for the help any links to buy what ever else i need is mucho apriciated, i owe you one!!
piddy
| posted on 20/4/06 at 06:35 PM |
Here's some that would do you nicely.
E bay link
Krismc
| posted on 20/4/06 at 07:11 PM |
they would have been nice, but ive got these 750 ones, now, so ill stick to my current plans!
zetec
| posted on 20/4/06 at 10:40 PM |
Bike engines in bikes - bike TBs on bike engines...simple.
| posted on 21/4/06 at 07:18 AM |
Bike TB's on car engines....money in wallet
Syd Bridge
| posted on 21/4/06 at 08:11 AM |
Does the engine know the origins of what is trying to choke its need to breathe?
Syd
Krismc
| posted on 21/4/06 at 02:44 PM |
Yea ill go the dave some money option i recon, unless i sell my car this week, like promised- sumone may come and ill have a wedge that i may splash
out and buy them after all,
but all will end in tears so ill consentrate on the bike tbs and stuff for the moment, i just need a manifold, ECU fuel pump and some bits and
pieces......
