Author: Subject: Starter Motor NOT Engaging.
Chaz
posted on 20/4/06 at 04:46 PM Reply With Quote
My starter motor is justing whirring round when i try to turn over the engine. I think its to do with the toothed pinion not moving down the shaft to engage the flywheel. It is supposed to move isnt it??? I tested it out of the gearbox, and when it spins it doesnt move along the shaft....is that right? If not how do i make it move?
I have mated a silver top zetec to MT75 with the original MT75 starter motor. I have been told that these do work together. I hope this isnt the problem.
stevec
posted on 20/4/06 at 05:09 PM Reply With Quote
If it is wired correctly a pre engaged starter wont normally spin until the pinion has been thrown out,
Has it ever worked or is this first try?
Chaz
posted on 20/4/06 at 05:20 PM Reply With Quote
This is the first try. I think its wired correctly. It is spinning, but is there a slight possibility that it spinning the wrong way (due to incorrect wiring) or is this impossible?
There are 3 connection points,
1 is earthed to the starter motor which i also have my premier wiring loom 'starter solenoid' (black/blue) wire going to it.
1 has nothing on it
1 at the top has the battery connected and loom main supply going to it.
Is that correct?
omega 24 v6
posted on 20/4/06 at 05:31 PM Reply With Quote
sounds like the solenoid is pulling in and starting the motor spinning but its not pulling the arm that slides the gear at the same time. Check the Pivot point and that the arm end is connected (mechanically) to the solenoid.
Chaz
posted on 20/4/06 at 05:53 PM Reply With Quote
I will have a look, but i have 2 starter motors the same. I've tried both and both work in exactly the same way, when wired up.
graememk
posted on 20/4/06 at 06:35 PM Reply With Quote
sounds like wrong starter or wrong fly wheel to me.
posted on 20/4/06 at 07:08 PM Reply With Quote
You could try it on the bench - hold the motor (firmly!) in a vise or workmate and connect a battery lead and earth - you should expect to see the pinion move and then spin.
Don't try this with the engine lying on the bench - it'll fling itself any which way!
Lawnmower
posted on 20/4/06 at 07:18 PM Reply With Quote
I noticed my landy is doing this after fitting a new starter moter (not a pre engaged one).
was only doing it when engine was hot, so maybe some sort of thermal expansion jamming summit, or the spring is stiff, or the sliding cog is sticking. yet to investigate, although my mate suggested removing it and greasing it up good and propper.
not to bothered as can also use the starting handle as a backup...
posted on 20/4/06 at 08:39 PM Reply With Quote
Greasing the bendix will provide a short term fix until it clogs up with clutch dust and stops working altogether...
Dusty
posted on 21/4/06 at 12:36 AM Reply With Quote
You've wired it wrong. The B/Bk goes to the smaller terminal, not the other large terminal that goes into the starter.
There isn't a bendix to grease. If the B/Bk is wired to the correct terminal it moves the solenoid which is a heavy lump of copper which first levers the gear into engagement with the flywheel ring gear and only then does it short between the solenoid contacts allowing current to flow to the starter itself.
ps. Don't test it on the bench. It will rip your hand off with the torque if wired correctly. Better to test it bolted in the car
[Edited on 21/4/06 by Dusty]
posted on 21/4/06 at 07:09 AM Reply With Quote
That's why I said fix it in the vise, or hold it in a workmate - the torque reaction is fierce.
posted on 21/4/06 at 07:20 AM Reply With Quote
Sorry for any confusion, I was replying to Mr Lawnmower!
Dusty
posted on 21/4/06 at 08:13 AM Reply With Quote
Apologies to Dave and Mike. I was just back from a day trip to Brum from Plymouth and was suffering culture shock. Didn't read your replies carefully enough.
Chaz
posted on 21/4/06 at 02:46 PM Reply With Quote
Woohoo, sorted. I did wire it correctly originally, just didnt earth it properly. Sorry for all the fuss. My engine has just turned over for the first time since i yoinked it out of its old escort home
Thanks for all the help!
