Markp
posted on 21/4/06 at 06:29 PM |
HELP ME PLEASE
After MONTHS of working on the car I tried to turn it over for the first time.
Nothing happens with the engine, it sounds as though the starter motor is missing the ring gear. I have had the starter out and it spins with no
problems.
It is a black top zetec with type 9 box, tiger lightened flywheel and the small type lucas sierra starter motor.
HELP ME PLEASE
Thanks Mark
stevebubs
| posted on 21/4/06 at 06:45 PM |
Missing by too much or too little?
If too much, try spacing the motor out with some spacers.
Alternatively, go down scrappies and get one from a 1.8 CVH Sierra - worked first time on mine.
Markp
| posted on 21/4/06 at 06:48 PM |
It doesn't seem to be reaching the fly wheel.
Whats the difference between the starter motors (1.8cvh), I thought that is what I had.
Cheers Mark
Mansfield
| posted on 21/4/06 at 06:58 PM |
I have a starter motor from a 1.6 CVH 1981ish and a starter motor from a 1992 1.6 CVH EFi Sierra.
I dont really want to part with either of them, but if you would like to borrow one, that would be fine with me. I am in Mansfield, NG18.
I dont know if either would fit, but they cant be that different, both ran on type 9 boxes.
DIY Si
| posted on 21/4/06 at 07:01 PM |
It is however the type of flywheel fitted that makes the difference. Any ideas what yours is?
Mansfield
| posted on 21/4/06 at 07:03 PM |
Both of my flywheels are exposed for viewing if required.
Show me yours, and I will show you mine.
DIY Si
| posted on 21/4/06 at 07:05 PM |
Always open to offers and all that, but mines buried deep in the depths of the garage!
Markp
| posted on 21/4/06 at 07:13 PM |
Does it look like this???
Markp
| posted on 21/4/06 at 07:15 PM |
or this?.JPG)
DIY Si
| posted on 21/4/06 at 07:27 PM |
Yup. Except mine's covered in mank. Sounds like you've got a different type of flywheel fitted.
Markp
| posted on 21/4/06 at 07:28 PM |
It's the tiger lightened flywheel. Surley it can't be this difficult!
Krismc
| posted on 21/4/06 at 07:34 PM |
i also got the FRS122 starter from tiger with there pinto lightened flywheel, looks like it may rub the side of the engine i may have to cut a inch or
so off!
DIY Si
| posted on 21/4/06 at 07:35 PM |
Not sure what they base it upon. That's what determines the starter. Try posting in the tiger bit. Someone must know what it is, since I
haven't got a clue. But as you say, it shouldn't be too hard to figure out.
Mansfield
| posted on 21/4/06 at 07:39 PM |
As I said, if you want to try either of mine you are welcome.
I think yours looks similar to my 1992 one.
Mansfield
| posted on 21/4/06 at 07:41 PM |
And with a huge picture
Mansfield
| posted on 21/4/06 at 07:43 PM |
Do you think your starter is constantly engaed, because my 1991 starter cant be.
Markp
| posted on 21/4/06 at 08:09 PM |
thanks for the replys so far.
I have had another look (i know it dark) The starter looks as though it is hitting the engine where the sump flange is.
Is it the correct width?
Markp
| posted on 21/4/06 at 08:10 PM |
another.JPG)
Markp
| posted on 21/4/06 at 08:12 PM |
krismc.
Does yours say frs122?
Mine is LRS707!
This could be the answer
[Edited on 22/4/06 by Markp]
Markp
| posted on 22/4/06 at 05:22 PM |
I have found the solution
I went and had a look at a car garage and picked up the lucas lrs543, it is slightly longer, put that in and works a treat
Life is good again!!
Mark
DIY Si
| posted on 22/4/06 at 07:08 PM |
Glad to hear you got it sorted. You'll be out on the road soon hopefully?
