Author: Subject: Exhaust sealing
amalyos
posted on 4/5/06 at 10:02 AM Reply With Quote
Exhaust sealing
Can you use Silicone to seal exhausts? Is there any special type to use?
I'd rather not use Gungum!!!
smart51
posted on 4/5/06 at 10:25 AM Reply With Quote
I used silicone to seal the ends of my repackable silencer - it doesn't get too hot. One end stiuck really well, the other peeled off after a few weeks.
I used an exhaust sealing cement to join the link pipe to the doen pipe. It worked really well. line the inside of the larger pipe before you push in the smaller pipe and you shouldn't see it.
MikeR
posted on 4/5/06 at 11:15 AM Reply With Quote
this was covered recently, the best idea seemed to be builders heat sealing something or other. Basically the stuff they use when fitting boilers. Never dries out, bit clay like, designed for the job.
posted on 4/5/06 at 12:16 PM Reply With Quote
There is a specific paste for that job - white stuff that goes hard when it gets hot. It's also supposed to act as an assembly lubricant when runny. It's not GunGum though - it's pukka stuff.
I didn't bother myself - I used copper grease! All my joints are a good fit, the grease will burn off, leaving a copper residue that will help me when I next need to take things apart (e.g. for repacking the silencer). It's bl**dy hard to separate the proper stuff after it's hardened.
MkIndy7
posted on 4/5/06 at 01:52 PM Reply With Quote
Theres 2 kinds of High temperaturte plumbers silicone used.
1 is for sealing between sections of boilers and that never really sets
And (PlumbaFlue trade name me thinks) thats high temperature silicone, upto about 400 DegC that is used to seal imbetween sections of Flue that sets like normal silicone
NS Dev
posted on 4/5/06 at 02:00 PM Reply With Quote
Yep, completely agree, I use the same, well actually nickel anti seize which is very similar to coppaslip. Helps as an assembly lubricant, and the joints should not leak anyway, shouldn't really need sealant if they are the right size.
Multipiece manifolds don't use sealant!
don't think Ned will mind me posting a pic of his manifold, no sealant here, and they are slip fits held in place by bolts, no clamps either........
side shot
side shot
posted on 4/5/06 at 02:14 PM Reply With Quote
Holts Firegum aka exhaust assembly paste.
posted on 4/5/06 at 02:20 PM Reply With Quote
That's the stuff!
Wouldn't use it again though - it's a damn fine cement when it sets.
jimgiblett
posted on 4/5/06 at 02:25 PM Reply With Quote
I find most exhaust pastes just crack and leak on bike engined cars (probably due to the vibration. I was recommended the Bosal putty as an alternative. But as I couldn't get hold of any I used the othe slternative clear silicone sealant (yes it must be clear so as to not contain any chalk which is usually the pigment carrier). I have regularly used silcone and it has worked very well. One tip is to make sure the silicone has properly cured before starting the engine and running hot gasses through the pipe.
Multipart exhausts seal via the expansion of the inner tube within the sleave so should not require further sealing. Repackable silencers however tend not to get a deformed seal concentrated around the rivets and a bead of silicone is just the job to form a seal.
- Jim
paulf
posted on 4/5/06 at 03:29 PM Reply With Quote
I have used the non setting type of sealant on my silencer, it was marked as suitable for sealing around fire doors etc and swells with heat. I found it alsts better than the setting type and is easier to seperate when required, it also has no acetic acid in it.
Paul.
