Humbug
| posted on 7/5/06 at 05:05 PM |
Cut down K-Series cam belt cover
Thanks for the inspiration at Newlands today (James, mainly).
I lopped the top off the plastic cam belt cover to reduce the engine height - longer term aim is to raise the nose cone by packing with 1-1.5"
square tubing, then make an aluminium bonnet with a smaller and neater bulge.
(and yes, I know I could just leave the cover off completely but I decide to leave it so it has some protection from debris)
1. Sliced off the top with a saw (3.5cm at the front end!)
2. all bare and naked!
3. New aluminium top fixed with shallow pop rivets
4. primed, painted and fixed back on
5. now much lower (with nose raised 1" .
Could be even lower relative to the nose if I raise the nose a tad more, or grind down/remove the plug cover - then maybe I could get away with a long
narrow bulge (sort of sausage shaped)?
Nice to go to Newlands for the first time today, by the way. I can hghly recommend the bacon and egg bap.
Cheers.
[Edited on 07.05.2006 by Humbug]
ned
| posted on 7/5/06 at 05:59 PM |
James spoke to you aswell did he Simon
looks like a good job you've made of it. what with a slightly taller nosecone and a new bonnet you should be able to fit it all under and clean
the lines up and ditch that bulge.
Ned.
beware, I've got yellow skin
GeoffT
| posted on 7/5/06 at 06:24 PM |
Jeez, that was quick!
'James' will have to be careful what he suggests next time you make an appearance
Good to see your K conversion anyway, should give me some inspiration to make a start with mine..!
ATB, Geoff.
Humbug
| posted on 7/5/06 at 06:35 PM |
Now I just need some advice and hints on making an alu bonnet
| posted on 7/5/06 at 08:14 PM |
When you get tips on making a bonnet pass them on to me please , need to replace the fibreglass one I have at the moment
Humbug
| posted on 9/5/06 at 07:06 AM |
Ned.
OK, OK. James, Ned, whoever... I'm a simple soul and get easily confused
I think I am still going to need some sort of bulge, otherwise the nose cone will have to come up about 3 inches and the bonnet top will be horizontal
front to back, which I think will not look so good.
[Edited on 09.05.2006 by Humbug]
