Danozeman
| posted on 12/5/06 at 01:24 PM |
Zetec cooling again..
Im plumbing my cooling system the same as the picture.
The little bleed pipe on the top of the rad, Am i correct in saying this should go back to the top of the expansion tank??
The tank im using has 2 small inlets at the top so its easy to do..
[Edited on 12/5/06 by Danozeman]
Dan
Danozeman
| posted on 12/5/06 at 01:27 PM |
Bloody pictures
Dan
muzchap
| posted on 12/5/06 at 01:48 PM |
Yup that's how I'm doing mine - should be finished this weekend.
I'm also connecting it via a T-Piece to the top of the thermostat housing then into header tank
[Edited on 12/5/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Danozeman
| posted on 12/5/06 at 05:27 PM |
Good good. where u getting your pipes from to do it all with?? Im having trouble and dont want to buy samco.
Dan
zetec
| posted on 12/5/06 at 08:55 PM |
The small bleed pipe on the top of the rad can be blanked off with a small bolt. I just remove the bolt when filling to bleed the rad and replace once
coolant flows out.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Danozeman
| posted on 14/5/06 at 10:32 AM |
Im using a Polo rad btw.
Where are these bits from??
Dan
Danozeman
| posted on 14/5/06 at 10:33 AM |
F'ing pictures.
Dan
nikpro
| posted on 15/5/06 at 05:22 PM |
All Westfields with a zetec and the Polo Rad blank off the top bleed nipple on the radiator as previously stated.
[Edited on 15/5/06 by nikpro]
My Build Pics:
http://www.pbase.com/nikpro/westfield_build
