Author: Subject: X-flow Contactless Distributor
Dick Axtell
posted on 13/5/06 at 01:42 PM Reply With Quote
Hi All,
Has anybody tried out the LocUst method of achieving locost electronic ignition?
(Ref: http://www.locustenthusiastsclub.fsnet.co.uk/knowlegebase/elec_ign/electronic%20ignition..htm)
Looks like a reasonable solution - but how effective is it? Who's had experience of this recommended distributor change?
procomp
posted on 13/5/06 at 01:47 PM Reply With Quote
Hi a lot of the locost racers use this dizzy instead of the original fomoco or the lucas unit . There is no reason not to use it should be good and reliable .
cheers matt
Markp
posted on 13/5/06 at 02:16 PM Reply With Quote
I used this set up for two years and never had a problem. worth doing
Mark
Markp
Mark
DIY Si
posted on 13/5/06 at 02:22 PM Reply With Quote
Pah. £20 my ar$e. He's been had, mine cost 99p form e-bay.
UncleFista
posted on 13/5/06 at 04:25 PM Reply With Quote
Mine cost a tenner from the scrappers, don't forget to get the coil too
Tony Bond / UncleFista
DIY Si
posted on 13/5/06 at 04:27 PM Reply With Quote
I'm assuming a lucas gold coil should work?
posted on 13/5/06 at 06:30 PM Reply With Quote
Yep - it's what I've got on my x-flow. When you go to the scrappy, just have a good look at the cross-shaped thing inside and see if anyone's been bending it about - otherwise they are fairly bomb-proof.
Apart from that, make sure that you get the connector that goes into the electronics pack that's screwed into the side of the dizzy. Also, if you can, take off the electronics, clean up the surfaces and re-fit using heat-conductive paste (available from Maplins).
Oh yes - you'll probably need to replace the coil for a 12v one, and remove any cold-start resistor that's in the circuit.
Once fitted you'll never have to worry about adjusting point again!
It's an easy mod, and well worth doing.
DIY Si
posted on 13/5/06 at 06:34 PM Reply With Quote
It's ok, I've already got a complete good nick dizzy and a spare coil. Justr didn't want to blow the elctronics up by using a 12v coil if it should be 9v.
Marcus
posted on 14/5/06 at 09:42 AM Reply With Quote
I tried this conversion and failed dismally!
Think I bought a pup, the only thing left to change is the electronic module - could I buggery get a spark!!
Marcus
Marcus
Because kits are for girls!!
posted on 14/5/06 at 04:07 PM Reply With Quote
All depends on whether you used the instructions in the Wallage book - I did, couldn't make it work - then found out that the wiring instruction heve gives are incorrect!
Wired it correctly and it worked perfectly.
Marcus
posted on 14/5/06 at 04:10 PM Reply With Quote
OK David,
How did you wire yours. there are only 3 wires, brown, black and green.
From memory,
Brown - chassis
Green - coil -ve
Black - coil +ve
Close?
Marcus
Marcus
posted on 14/5/06 at 04:28 PM Reply With Quote
That's the correct way - Wallage had the black and green swapped over.
The amplifier modules were liable to overheat when the metal they're attached to gets corroded. It may be worth trying another one, but clean the metal with some wire wool and apply some heatsink compound before refitting the module (available from Maplins).
[Edited on 14/5/06 by David Jenkins]
Dick Axtell
posted on 30/5/06 at 04:17 PM Reply With Quote
Thanks for all this VERY useful feedback, guys. Now it's off to the local scrappers.
Dick Axtell
posted on 3/6/06 at 11:54 AM Reply With Quote
FAO David Jenkins & Marcus
Got the distributor and connector. So far so good.
What is the purpose of the metal shield, surrounding the cap? Do I have to retain it on the Locost?
Dick
posted on 3/6/06 at 03:12 PM Reply With Quote
The metal shield is something to do with radio/TV suppresion , left it off when I changed mine . Well worth fitting Valencia distributor even if only for not having to change /adjust points
posted on 3/6/06 at 03:34 PM Reply With Quote
Like he said - you don't need the metal thingy.
Dick Axtell
posted on 4/6/06 at 01:08 PM Reply With Quote
Again, thank you for the feedback.
Dick
