Author: Subject: Spark plugs
flak monkey
posted on 16/5/06 at 02:45 PM Reply With Quote
Spark plugs
Choices choices...why is nothing ever simple?
There are 3 possible NGK sparkplugs for the pinto engine:
AP6FS is the std plug
AP7FS is for 'fast road'
AP8FS is for 'rally/race'
Question is should i fit the AP6 or AP7 ones? Will it make any difference at all? Moderately tuned pinto. I know the difference between the plugs is their 'heat'. I know its critical in RC model engines...thats the only reason I ask.
Sera
http://www.motosera.com
posted on 16/5/06 at 03:05 PM Reply With Quote
I was told in no uncertain terms that the standard spark plug should be used unless something indicates that you need to change.
If your engine is pinking then go to a colder plug; if your plugs are oiling up or fouling then go for a hotter one.
Try
this link for NGK data
flak monkey
posted on 16/5/06 at 03:20 PM Reply With Quote
Cheers David
Sera
