darrens
posted on 22/5/06 at 05:43 PM |
Tank baffles
How many would one normally put into a 8-9 gal tank
cheers
[Edited on 22/5/06 by darrens]
muzchap
posted on 22/5/06 at 06:10 PM |
Hi mate - in mine I have 2 - either side of the swirl pot (middle).
It depends on where your feed to the fuel pump is going to be...
In tank foam is also highly recommended.
I have some pics somewhere of my tank pre-construction and with measurements - let me know via U2U if you need
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Bob C
posted on 22/5/06 at 07:30 PM |
Now I've tried it, I recommend my baffle system - any sloshing of liquid in the tank results is a clear couple of inches extra depth in the
middle bit - photo on
http://freespace.virgin.net/bob.carter/images/tankbaffle.jpg
diagram attatched
Bob
wildchild
posted on 23/5/06 at 09:02 AM |
That looks like a pretty good idea.
First time I looked at it I was a bit confused as I assumed it was a horizontal section rather than a plan view - was wondering how you could use the
fuel in the right hand side!
