9000rpm
| posted on 26/5/06 at 10:03 PM |
Engine Size
Hi all, I am new to this forum and be reading/searching for the past month.
I am after a AWD chassis with 50/50 weight front/rear(or near). I am not after ready made kits such as DAX. I want a DIY
Some help needed here
1) Have similar locost been done with High powered engine (+350whp)?
2) Which chassis would be good for this project ?
Donor cars
My first choice was a Skyline but the engine+gearbox would be enormous for a locost. Although there are many tyres of AWD Skyline engines, they are
all 6 cylinder
L x W x H
RB20DET: 845x660x685
RB26DET: 870x665x675
RB25DET: ???x???x???
I do not have any info on the gearbox size, but from pics it is easily noted that its roughly the same length as the engine.
3) would you suggest to scrap the Skyline idea and move to a cossie ?
This kit car will not be used on legal roads and only used for races such as Hillclimb.
4) Would it be best practice to design my own chassis to put in such engine+gearboox.
Ev.
geoffreyh
| posted on 27/5/06 at 01:00 PM |
It looks like you want to build a front engined AWD car.
I haven't seen a lot of AWD cars in this forum. I know one guy who is building a side engined AWD sportscar. You can have a looks at Dennis DP1
at www.dpcars.net
If you thought of using a locost7 chassis for your car it will be quite tricky. The steering rack and front suspension of a locost are almost
completely in the front and I presume your engine is in front of the transmission. You will probably have to adapt the front of the chassis to be able
to use the skyline engine.
I can be wrong but that's how I see it.
Regards,
Geoff
meany
| posted on 27/5/06 at 01:12 PM |
ther is/was someone on here buliding 4wd 7 type, using the ford v6, he/she has pictures in the Photo Archive, but i cant rember who it is/was.
flak monkey
| posted on 27/5/06 at 01:16 PM |
IIRC Liams building a 4wd 'locost'. Dax make a 4wd seven out of the factory.
Have fun fitting a skyline engine in a seven though...  Good luck using all 350bhp in a car that weighs less than half what a skyine does...its
not about how much power you have, its about whether you can trasfer it to the road
Sera
http://www.motosera.com
meany
| posted on 27/5/06 at 01:25 PM |
thats the guy.
liam's photos
geoffreyh
| posted on 27/5/06 at 01:35 PM |
Is there anyone who can tell me how the linkage to the front is done on Liams car?
It looks like it runs on the right side of the engine but from where?
Geoff
Chippy
| posted on 27/5/06 at 03:53 PM |
Assume you are talking about the drive shaft to the front dif. looks to me as though he has fitted the type 75 gearbox from the ford 4x4i, and if so
the transfer box is on the right, (you can just make it out on the pic from above), he hasn't fitted the drive shaft yet. Hope that helps. atb
Chippy
9000rpm
| posted on 27/5/06 at 04:26 PM |
Gearbox including transfer case that off a Skyline
9000rpm
| posted on 27/5/06 at 04:28 PM |
Engine RB26DETT
9000rpm
| posted on 27/5/06 at 04:31 PM |
quote: Originally posted by geoffreyh
I know one guy who is building a side engined AWD sportscar. You can have a looks at Dennis DP1 at www.dpcars.net
This looks promising
