Author: Subject: Sealed universal airbox, any ideas???
se7ensport
posted on 31/5/06 at 11:39 AM Reply With Quote
I'm looking for a universal airbox to suit bike carbs or twin webbers, that I can run a 76mm ID cold air feed into.
Demon "I'm going to bend you over and rob you blind" theives do a carbon version for approx £300…..
Has anyone seen an ABS or fibreglass version for a sensible price? I did plan to use an existing R1 box but it looks a bit too big for available space, although may chop and reshape if required.
mike smith1
posted on 31/5/06 at 11:54 AM Reply With Quote
IIRC Triton has one in his photo archive,
Mike
Stuart Walker
posted on 31/5/06 at 12:00 PM Reply With Quote
Plays Kool do this one, if you go to the website www.plays-kool.co.uk and download the brochure, its on page 5.
DarrenW
posted on 31/5/06 at 12:30 PM Reply With Quote
Pipercross had them on their stand at Stoneleigh.
Do they flow as well as a std sausage type filter?
skydivepaul
posted on 31/5/06 at 12:46 PM Reply With Quote
Best to call playskool first as i am sure Paul reduced trading at Playskool to go back to the building trade earlier this year.
Why not buy some carbon fibre sheet from e bay and make your own. 1 metre square cost me about 15 quid. I reckon 3metres and some fast glass resin would do the trick. You can make it to your exact requrements then.
Stu
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
se7ensport
posted on 31/5/06 at 12:59 PM Reply With Quote
Its not so much a flow issue, but a temperature one, the cooler the air the denser the mixture and the bigger the boom.
I had no idea carbon sheet was so cheap, I'll check out ebay and plays-kool.
Cheers guys
Alex
TangoMan
posted on 31/5/06 at 05:15 PM Reply With Quote
Locost Solution
I went for the locost solution and made one out of thin ally sheet.
It looks a bit boxy but does the job well. I had two aims, one to reduce intake temperature and two to reduce intake noise (as I want to get below 98db for Donington)
It works on both counts.
Interestingly I fed the inlet hosing to the front grill to get forced induction at speed. It worked too well as at about 40 the engine started struggling as the mixture was all wrong. Anyone with electronic injection using MAP could possibly utilise this, although it would need to cope with positive presssure as well as negative. Food for thought!!
I will post some photos when I remember to take the camera to work.
jack trolley
posted on 31/5/06 at 05:22 PM Reply With Quote
I recall seeing a pic. (in CCC?) of a airbox made from a plant pot
- (the rectangular trough type ones).
se7ensport
posted on 1/6/06 at 10:16 AM Reply With Quote
I like both ideas, B&Q here I come!
DarrenW
posted on 1/6/06 at 10:21 AM Reply With Quote
Interesting alternative
http://www.mci.i12.com/carbon/air_filter.htm
se7ensport
posted on 1/6/06 at 10:56 AM Reply With Quote
Would forced induction, not turbo or s/c, but pipe behind grill running to a sealed airbox cause any issues with bike carbs?
The reason I ask is that most superbikes have air intakes located at the front/leading edge of their bodywork which must generate positive pressure, and as long as the carb is designed to cope it shouldn't be a problem.....
DarrenW
posted on 1/6/06 at 01:14 PM Reply With Quote
Thanks sevensport!!!! Youve set me off now as well.
Ill probs just fit sausage type filter to my bike carbs but...........
what would stop you making an airbox and connecting it to a charge cooler.......
Ive just started a seperate topic rather than hijack.
[Edited on 1/6/06 by DarrenW]
DarrenW
posted on 1/6/06 at 02:23 PM Reply With Quote
here is Tritons airbox
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Airbox%202.jpg
i wonder how much they are?
An intersting thread from 6 months ago
http://www.locostbuilders.co.uk/viewthread.php?tid=35638&page=1
TangoMan
posted on 1/6/06 at 10:24 PM Reply With Quote
Mine certainly didn't like it but then I would probably need to be much richer top end. I would think it would be very difficult to gauge properly with carbs because speed would increase forced air but this would not always be at the same revs or throttle openings. I can't see how carbs could cope with this.
