violentblue
| posted on 13/6/06 at 04:15 PM |
zetec bike carb manifold?
can you purchase these or is it a DIY job?
a few pics of my other projects
Danozeman
| posted on 13/6/06 at 04:38 PM |
Bogg bros do them which use the same spacing as the bike carbs.
Linky
Not the cheapest but bloody good work.
IIRC theres someone on here looking at making some. Cant remember who thou.
These are my bogg bros jobbie
  carbs
You can make your own if you can cut the plate etc. YOul need to space the carbs out further to make it easier.
Dan
trogdor
| posted on 13/6/06 at 04:42 PM |
i believe the mondeo ST170 zetec has a manifold that will bolt up to any zetec and allow bike throttle boddies to joined up with connecting rubbers. i
see no reason why bike carbs won't fit either!
it may require alittle respacing of the carbs, but hopefully someone else will know abit more about it!
Danozeman
| posted on 13/6/06 at 05:48 PM |
The st manifold will fit bike carbs too. You just need to change the carb spacing and get some rubber pipe to connect. IIRC theres a little other
mod you have to do aswell.
Dan
