nludkin
| posted on 26/6/06 at 02:43 PM |
Rover V8 to Ford MT75
Does anyone know if it is possible to connect a Rover V8 to a MT75 box? I currently have 2 good condition MT75 gearboxes and would hate to get rid of
them if I could use them via a simple bellhousing adapter.
froggy
| posted on 26/6/06 at 04:56 PM |
you can mate them with an adapter plate as liam has done with his rover v6 or do it the hard way and mate the front of a rover bellhousing to the mt
box. unless you want four wheel drive there are other options for the rover lump such as t5 or supra boxes
nludkin
| posted on 27/6/06 at 07:16 AM |
Cool, so adapter plate it is then. I will start phoning around today to see if anyones up for the challenge :-)
Cheers.
Liam
| posted on 27/6/06 at 10:09 PM |
Wouldn't call your way the hard way neccessarily Froggy!
You need to have a good look and a measure to see what you got to play with. For example the RV8 flywheel may not fit in the MT75 bellhousing; or the
clutch spline on the gearbox input shaft may not be where you want it etc etc. Or it may work out fine.
It was OK for me cos i have a buddy who could machine me a custom ally flywheel to fit my honda engine and take a ford clutch and compensate for the
thickness of the adaptor plate. You've then got to mount the starter motor somehow.
Cutting and shutting a bellhousing means you can definately use standard flywheel and clutch and starter mounting, but you need access to big machines
to get the cut faces true and of course good ally welding. The steel adaptor plate suited my skills and access to machinery, but cutting and shutting
a bellhousing may well be cheaper and simpler for someone with the right stuff.
Liam
TL
| posted on 28/6/06 at 12:34 PM |
RV8 flywheel won't fit in a DOHC bell housing. I'm pretty sure it won't even fit in a V6 bellhousing, the the cut & shut
MT75/RV8 bellhousing is about the easiest way to go, but even then it is crucial to get the alignment spot on, both concenticity and angular. I did
this myself. (I have access to machines), and had it tigged.
I never got round to using it, so an appropriate amount of money might part me from it
The easiest way is to sell your 2 MT75s & buy an LT77. By the time you mess about paying for machining and / or tigging, it will probably be
cheaper.
HTH
Terry
