givemethebighammer
| posted on 29/4/03 at 08:42 PM |
Motorbike carbs on a Zetec and Xflow Engines
I have found a few websites where people have used Suzuki GSXR carbs on their Zetec and XFlow engines. However there is little detail about which
exact model of bike the carbs were from and and modifications that were required. Anyone else tried this. Just you can buy a set of 4 Suzuki GSX 1100
Slingshot carbs from the breakers for £100 !!! Also the GSXR 750 RR (1989) used 4 x 40mm carbs. Nice and small too for anyone wanting to save
space.
Maybe this is the topic to unite the bike and car engine factions of this group ???
[Edited on 29/4/03 by givemethebighammer]
Cazzy R
| posted on 30/4/03 at 12:30 PM |
Hi.
I'm interested in that. What are the URLs?
givemethebighammer
| posted on 30/4/03 at 09:02 PM |
Found a dutch site where a guy had used what I think are Suzuki GSX1100 carbs with his zetec, can't find the site now but pictures attached
[Edited on 30/4/03 by givemethebighammer]
givemethebighammer
| posted on 30/4/03 at 09:03 PM |
Pic 2
givemethebighammer
| posted on 1/5/03 at 09:03 PM |
These photos belong to Siert, he has a photo archive on this site. Not seen any postings from him recently though. Anybody know where I can contact
him ???
martin s
| posted on 6/5/03 at 07:39 PM |
website
http://home-1.worldonline.nl/%7Esvos/carbs.html
Simon
| posted on 7/5/03 at 09:34 AM |
Maybe I should get two lots for my R V8
Simon
-Gaz-
| posted on 9/5/03 at 05:23 PM |
motorbike carbs on car engines is something ive been interested in for a while, but still havent managed to find out much. i can tell you that those
pictured are not of std gsxr carbs, they are aftermarket keihin FCR flatslide carbs which you will struggle to get for less than 300 quid secondhand.
as far as i know very few bikes these days use flatslides as std which is what you want ideally. most bikes now come with CV or constant velocity
carbs which are much harder to set up, and basically operate like an old SU, ie a butterfly type throttle and vacume controlled slide. with the
flatslides the slide is actually the throttle. there, that about all i know.
martin s
| posted on 11/5/03 at 03:07 PM |
another website on motorbike carbs
this ones got abit more info on http://www.triumphspitfire.com/carbchoices.html
[Edited on 11/5/03 by martin s]
givemethebighammer
| posted on 11/5/03 at 10:46 PM |
interesting I have emailed the triumph guy for more info
GO
| posted on 26/9/03 at 10:13 AM |
givemetheibghammer, did you get a reply from the spitfire guy? I'd be interested in anything he had to say as well.
Ian Pearson
| posted on 26/9/03 at 02:49 PM |
I'd be interested too. I e-mailed him a while back and have heard nowt.
givemethebighammer
| posted on 27/9/03 at 12:31 PM |
No reply here either, I have since managed to find a cheap £150 pair of Dellorto DHLA 45's. Need a good clean and a few new jets (ones in then
are too big) but otherwise look good.
Try here:
http://www.lotuseliteparts.bravepages.com/
based near Rugby in the sticks has all sorts of Lotus spares even offered me a whole running 900 series engine, I declined on basis that spares could
prove expensive and I already had a perfectly good 2.0L zetec.
givemethebighammer
| posted on 8/2/04 at 10:16 PM |
Found some hard evidence of people using bike fueling on a zetec:
quote from Rhocar site:
I have just finished installing a 2lt Zetec in a 2b. Starting from back to front , To utilise the standard coil and thermostat hosing etc I moved the
gearbox forward by 5", this involved a modified prop and mount brackets for the gearbox, The gear lever was returned to its original position by
the use of a westfield type 9 gear extension which moves the gearstick back by 5 1/4". The clutch was easy in my case, I don't know all of
the different variants but I managed to use a standard zetec clutch from a 1.8 escort 130hp and this works fine with the sierra release bearing, this
keep the maximum friction plate size possible. Using the standard sierra rubber engine dampers new mounts were fabricated. One of the main problems I
encountered was the sump. If you position the engine level with the chassis aligning the propshaft ground clearance isn't a real issue however I
did remove about 1/2" from the bottom to give a level bottom. The main issue with the sump was using the standard pinto starter motor as
material has to be removed from the side of the sump to allow it to fit but not to much or else the big ends collide, its a bit of a fiddle but worth
it. I am using throttle bodies from a 2003 yamaha r6 (38mm, bigger is not better)using the standard r6 injectors which flow around 235cc/min which is
plenty for 200bhp, combined with an MBE 941 ECU. Inlet is a problem in a 2b if you stick with the servo assisted brakes, I don't think carbs
would fit without modification. The results are amazing. Any questions just ask I am happy to help if I can.
I know it is throttle bodies, but shows it can be done:
http://community.rhocar.org/index.php?showtopic=2543
