donut
posted on 1/5/03 at 05:22 PM |
2 litre pinto. car or Transit?????
How can i find out (without a strip down) if my 2 litre pinto is from a Transit van or not. I have been told that it 'may' be from a
tranny which i'm happy with. Are there any differences?
cheers
bob
posted on 1/5/03 at 05:33 PM |
ANDY
Give the FORD technical helpline a call.
0906 5533447
And give them the eng number,they will then tell you where the lump started life and what in.
donut
posted on 1/5/03 at 06:15 PM |
Blimey Bob, that was quick!!!
I'll give them a ring in the mornin
david walker
posted on 1/5/03 at 07:56 PM |
2.0 Pinto Transit engines use 1600 Pinto car camshaft, so that would be easy to change before fitting engine into chassis. They also run with low
compression pistons. These are still flat topped but are about 50 thou short of the top of the block. Sierras run with 9.2:1 compression whereas
Transits are 8.2:1.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
billy
posted on 1/5/03 at 08:00 PM |
transit??
i think you can find out quite easy ......if you drive past a jewson or similar youll find it will pull to the side the yard is on....must be out of
habit...
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
stephen_gusterson
posted on 1/5/03 at 08:36 PM |
van versions of engines tend to be downtuned and make a bit more torque
atb
steve
donut
posted on 1/5/03 at 09:58 PM |
Billy
That's the funniest answer i have ever received!!
MK9R
posted on 2/5/03 at 06:47 AM |
Easy to tell, if your car is the fastest on the road its definetly from a transit!!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
donut
posted on 2/5/03 at 07:10 AM |
I like the sound of that Austen!!!
posted on 2/5/03 at 09:33 AM |
Transit engine.
If it's like the transit's round here it's probably done a quarter of a million miles and been run without oil or water with two
tons of bricks in the back and a wacker plate or two. If I was you I would change the camshaft.
yours, Pete.
billy
posted on 2/5/03 at 09:37 PM |
all this talk of transit vans,brings back real bad memorys of me driving a 1600 petrol transit for about 12 months,my god the fuel i put in that
beast...........
